yep, but it's a new toy so I think I'm gonna keep it like that for now...cool and stable... I just saw another guy in this forum with my same batch using 1.18v...looks like this batch works fine with low voltages.
Working on solid 4ghz with low voltage. I have come down quite a ways and right now I'm at 4GHZ with 1.232v
21x192 multiplier
DDR3@ 2:8 7-7-7-21 1.53v
Pleased with this. I'll keep going lower on the voltage.
http://valid.canardpc.com/show_oc.php?id=1406141
Looks good! Try and go higher!
Target CPU Frequency 4200MHz
Target DRAM Frequency 1683MHz
LN2 Mode [Disabled]***
QPI Loadline Calibration [Enabled]***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [Auto]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
MPS and ACPI MADT ordering [Modern ordering]
Intel(R) Virtualiyation Tech [Enabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Intel(R) Turbo Mode Tech [Disabled]
Intel(R) C-STATE Tech [Enabled]
C State package limit setting [Enabled]
BCLK Frequency [210]
PCIE Frequency [102]
DRAM Frequency [DDR3-1683MHz]
UCLK Frequency [3365MHz]
QPI Link Data Rate [7572MT/s]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency [7]
RAS# to CAS# Delay [8]
RAS# PRE Time [7]
RAS# ACT Time [20]
RAS# to RAS# Delay [Auto]
REF Cycle Time [88]
WRITE Recovery Time [Auto]
READ to PRE Time [Auto]
FOUR ACT WIN Time [Auto]
Back-To-BackCAS# Delay [Auto]
Timing Mode [1N]
Round Trip Latency on CHA [Auto]
Round Trip Latency on CHB [Auto]
Round Trip Latency on CHC [Auto]
WRITE To READ Delay(DD) [Auto]
WRITE To READ Delay(DR) [Auto]
WRITE To READ Delay(SR) [Auto]
READ To WRITE Delay(DD) [Auto]
READ To WRITE Delay(DR) [Auto]
READ To WRITE Delay(SR) [Auto]
READ To READ Delay(DD) [Auto]
READ To READ Delay(DR) [Auto]
READ To READ Delay(SR) [Auto]
WRITE To WRITE Delay(DD) [Auto]
WRITE To WRITE Delay(DR) [Auto]
WRITE To WRITE Delay(SR) [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full Calibration]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [1000KHz]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage [1.36250]
CPU PLL Voltage [Auto]
QPI/DRAM Core Voltage [1.48750]
DRAM Bus Voltage [1.65625]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage [1.17925]
IOH PCIE Voltage [Auto]
ICH Voltage [Auto]
ICH PCIE Voltage [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
***on-board jumper dependant
How do you know this?Default ViD is 1.275v.
Thank you.
With all settings defaulted like that, C1E, EIST, Turbo, HTT on, I get 1.216 V in CPU-Z w/ /LinX. So I'm good?
EDIT: Hmmm...once LinX starts to really hammer the CPU, it's actually 1.152 V. Woot!
[H]ocusPocus;1036206491 said:This is still a work in progress:
User Name: [H]ocusPocus
CPU: i7 930
FPO/Batch #: 3003B140
Store: Intel Online Store
Purchased In: August 2010
OC: 4009.1 MHz
Stability: 100 runs LinX (all mem) and 20+ hrs Prime95 (blend)
Temp (Idle / Load): 33c / 71c
Hyper Threading / Turbo Boost / Multiplier: Yes / No / 21x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.3V set in bios, 1.288V reported by cpuz
Cooling: Air
Cooler brand/model: Zalman CNPS10X Performa
Motherboard: ASUS P6X58D-E
Bios Version: 0303
Operating System: Win7 64
RAM brand & type: OCZ 3x2GB DDR3
RAM Part #: OCZ3G1600LV6GK
RAM rated speed: 1600 MHz
RAM actual speed: 1527 MHz
RAM Latency: 8-8-8-24 1T
RAM Voltage: 1.64V
User Name: Zoson
CPU: i7 930
FPO/Batch #: 3001B461 (pack date 6/09/10)
Store: Microcenter, Westbury, NY
OC: 4.206Ghz
Stability: LinX 8192MiB 50x runs passed
Temp (Idle / Load): 47C/96C
Hyper Threading / Multiplier: Yes/21x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.363v
Cooling: Water
Cooler brand/model: EK Supreme HF Gold, 2x GTX-120 + GT Stealth 120, 3x Enermax
Nice over clock. The temps do seem too high though.
Do you think a Corsair H70 would help your build out?
Nah.
I have two BlackIce GTX 120's and a single BlackIce GT Stealth 120.
They cool my cpu, motherboard, and both of the cores of my GTX275's. Memory and Power for my GPU's are cooled via Unisink. So I've got way more cooling than an H70, but way more to cool with it, also.
The fans I have on my rads only spin up to ~1650rpm at full speed. Nice and quiet rig, even at full load. Linpack is the only thing that can make my cpu get above 90... 4-5 hour sessions of TF2 only brought me up to 77C, and that's with my gpu's being run also. Prime will top me out at about 88.
I am probably going to do some heavy modding to my case so that I can fit in more radiators soon.
Yeah, batch isn't very good. I got two chips. This was the better of the two. The other one needed 1.35v to even do 3.8GHz.Your volts are very high for 4.2GHz. Should be between 1.28-1.32v for a good batch of CPUs.
I guess your batch is not that great if you need 1.36v. 96C is crazy high, you really want to max out at 85C. A custom WC loop should be 65C or lower.
With an H50, I got 4.2Ghz @ 1.28v - 81C. With the Mega I lowered my temps to 77C max.
User Name: Blind Man
CPU: i7 930
FPO/Batch #: [dont know, box is at home, will update next weekend]
Store: Newegg.com
OC: 3990Mhz
Stability: 20 runs LinX
Temp (Idle / Load): 38c / 65c (highest core)
Hyper Threading / Turbo Boost / Multiplier: No / No / 21x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.2v in bios
Cooling: Air
Cooler brand/model: Megahalems Rev. B in push/pull
Motherboard: Gigabyte X58-UD3R Rev 2.0
Bios Version: FB
RAM brand & type: G.Skill 3x2GB DDR3
RAM Part #: F3-12800CL9-2GBNQ
RAM actual speed: 1530 (190x8)
RAM Latency: 9-9-9-24 1T
RAM Voltage: 1.64V
First time overclocking a CPU seriously, used the guide @ TechReaction
I had issues getting the BCLK to 200 with the QPI@1.36V so I dropped it to 190@1.34V and it has worked fine
so far. Didnt play around with trying for lower ram voltages or timings and have not tried for lower volts on the cpu (just set to 1.2 to be safe when i started).
Not sure if i should try the QPI @ 1.38V+ to try for 200 BCLK, or turn HT on.
Up the CPU voltage to 1.3 and try again maybe?
what voltage would be safe with my i7-930 and the corsair H70 ? right now I have 1.3v and under max load I hit about 62c max
User Name: Voleric
CPU: i7 930
FPO/Batch #: 3002A601
Store: Microcenter - Fairfax, VA
OC: 4000.06
Stability: WIP (20 runs LinX stable)
Temp (Idle / Load): 38/72
Hyper Threading / Turbo Boost / Multiplier: Yes/No/20
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.280v shown in CPU-Z (1.300v selected in BIOS)
Cooling: Air
Cooler brand/model: TRUE with single Thermalright 1600rpm fan
Motherboard: Gigabyte GA-X58A-UD3R v. 2
Bios Version: FB
Operating System: Win 7 64
RAM brand & type: Corsair 3x 2GB DDR3
RAM Part #: (Example: OCZP1333LV2G)
RAM actual speed: 1600
RAM Voltage: 1.65v
Very much a work in progress. My first attempt and I thought I'd go for 200MHz bClk, 4GHz with RAM at rated speed (mem multiplier at 8x) and UnCore at 2x mem multiplier (16x). I tried these settings with all voltages at auto but it wouldn't POST. Set CPU Core to 1.3000v and launched right into Win7 and tested temps with Prime, they looked ok, so I ran the 20x LinX test. So far so good.
I have that same board....love it! Nice working hitting 4ghz right out of the gate. I wish this thread included QPI/VTT voltage. May I ask what yours is set at?
My i950 will hit 200x20 at 1.25 volts with a max temp of 70 degrees at full load, something sounds off with your H70.
I am using a NH D14.
Heebs, with HT on or off?
Is that Linpack tested? If not... You haven't found your max temp. You've gotta leave it going with the case closed for awhile... I'm talking 10+ hours LinX stable.
Nothing can heat your system up like a Linpack based stress tool.
