PCI slot cooler from Thermaltake for like $15 did push my non-OC temps @ full load to 80C for the GPU core, but I mean when I had my gtx 260 in my other rig, an Antec 900, the OC'd temps with the side panel on and all 5 HUGE fans blasting away was only 70C @ full load 45C @ idle!!!!!! LOL, such a HUGE difference
Honestly I had these issues with a 8800GTS 640mb too, friggin 90C
Any thoughts about the Thermalright HR-03 GTX????
Yea man RMA that shit - only ATI cards are allowed to get that hot![]()
Whoa - Whoa..
Uncalled for.
My X2 runs at 32/37C idle at auto fan speeds, never gets above 60C. And it's quieter...
Im sure many would rather get one from the egg for $90 shipped and do the window mod themselfs![]()
Plus, assuming you have a video card that exhausts it's hot air out the back, the BS-08 would only suck up that hot air and blow it back into the case again. I would just use the default airflow and add the BS-08 as exhaust.I would have the BS08 exhaust and put it as close to the top of the case as I could. It really needs a blowhole from the factory.
I've got a DVD drive in the top bay, an HDD in the middle bay in a 3.5" to 5.25" adapter, and another HDD in the bay below that. I got lucky, and got fairly quiet hard drives, and any sound is easily dampened by the noise dampening material I've got and drowned out by a window fan.mentholmoose, I assume that's a harddrive under your DVD (or whatever) drive? How do you silence that thing? I kept mine there for a day and that noise was just awful.
I'm not using 8800GT's. Right now I've got a Sapphire 3870, and I'm going to be getting a 4850 for more than two monitors.Mentholmoose, there is barely just enough clearance for the fan to not hit the top of the case, but your original card, will have the hr-03 mounted on the back, so its close to your big CPU cooler, and the new card will be mounted on the front, so it will be VERY close to the top, but there is space, but more importantly, an x48....SLi capable????? I know for sure it does crossfire but you will be doing 2 8800GT's...so...yeah...think about that one.
Could someone measure if there is enough space to fit Thermochill PA120.1 radiator in front (removing the drive cage)? If it does, it would be awesome as i could have 120.3 in this small case - 120.2 fits on top, as someone here has done it.
Yes, it fits, barbs down or up. I will put 120.3 on bottom, so may be you could do same thing - instead 120.2 use 120.3 - less barbs, less leaks![]()
Will this case be able to handle/accomodate a GTX295?
If it can fit my 4850x2 (or 4870x2) it will be able to fit your GTX295
Judging by the pictures in this thread, yes.
I was seriously considering moving to an A05B once I start my new job and I had a couple concerns:
crayzie418 said that he had temp problems with his 8800GTS, I have 2 of them in SLI, will it be too hot?
(I could always get a PCI cooler, would that work?)
Also, someone told me that he had an A05B for a while but his temps were WAY high because of the heatpipes on his motherboard. I have the Asus M2N32 Deluxe wireless edition, will this overheat? anyone know?
With those temps, do you really need to? That's great news. I wouldn't mind getting another PC-A05B but I just bought a new case.I used to have SLi issues, but as I stated with an update reply, my GTX 295 is running cool right now, I just have to replace the case fans with 2 Scythe Kaze 110cfm fans and moved one of those fans onto the side panel right near the inlet of my video card fan. I would not hesitate to SLi 2 GTX 260's, you shouldn't worry either. My temps as speak with ambient temp being about 70 F is 34C on my [email protected] and my GPU @ 700/1500/2400 idle @ 42C and full load @ 55C, my northbridge is at 45C and I have a 780i. SLi if you want to!!! Don't worry, just get some better fans that actually push air, that's it. No need to spend $60 on HR-03 coolers, if you have adequate case cooling, push the air out the top of the case if you can too, im planning on drilling out holes out the top too!
All you have to do is go to the 'search this thread' at the top of the page and search for "water". A bunch of people's watercooled A05's are listed.Thanks. There's a lot of info to comb through in this thread. I didn't feel like reading the entire thread.
Anyone successfully fit water cooling equipment in this case?
Got mine back from the anodizer today. still have to get some decent pics. Maybe tomorrow.
