ChrisMorley
Banned - Will Not Accept Administrator Messages
- Jul 19, 2006
mattt said:none of the pictures seem to work for me, could you host somewhere else? :O
Email me I'll send you the pics...email in sig.
wpeng said:Sorry, I didn't see in the thread, but is this aluminum or steel?
Has anyone here attempted to install a watercooling setup in this case?
The airflow is back to front from the factory. The rear fan is an intake, and the front fan is an exhaust.IF you have the front as an in and the back as an out wouldn't the heat form the PSU affect the front intake? Also it seems that this setup would mess around with the airflow inside.
looks like people with 120 / 140 mm fans in their PSU are pretty airflow impeded... unless you hack up the HDD cage.
exactly what I was thinking, any chance of fitting a 240mm rad on the top(blowhole). might block a pci slot or two, but otherwise?
could probably get away with a single 120 on the back(intake fan).
hmmm?
I dunno about the airflow of this case. I know that most people don't have their case(s) facing them, but I'd be quite annoyed if the front exhaust was blowing on me.
I'd also be concerned if the back of the case were close to the wall. I'd rather the intake have plenty of breathing room than the exhaust.
The case is quite sexy though, save for the top-mounted ports (although if the case is positioned below you near the floor it's quite convenient).
I think he's referring to the fact that PSUs with 120+mm fans have them set on the top of the PSU. When mounted in this case that either means the fan will be pointed at the bottom of the case or the hard drive cage and either way airflow is less than desirable. It's one reason I'm opting for the Silencer 610w for my next build: it has a single 80mm fan on the front of the PSU so exhaust shouldn't be a problem.Where do you get this information?
You can't stick the case too close to the back of the wall otherwise how would you be able to plug in any of your perepherals?
I didn't think anyone would actually think I had my case up against a wall and turned on without anything plugged into the back, but thank you for the benefit of the doubt.
Yes, but the bracket is rotatable so you can have the intake face either way... also, the psu is lifted from the bottom of the case and has a large standoff from the base... so you wont have any airflow constraints.
hey Ockie...
do you think that the spacer is sufficient to give a PSU enough breathing room if I mounted a PSU with the fan facing down?
I was debating on whether to dremel out a hole on the floor of the case for the PSU but the low stance of the case really won't allow THAT much air anyways...
I'm having a hard time figureing this out: How many, if any, of the Lian Li aluminum CD drive bezels/doors come with this case?
It's pretty good actually. I swapped out the default fans for yate loons and I can feel the air coming out of the side vents on the front panel. It certainly isn't going to compete with an Antec 900 or Stacker or something else with 4+ 120mm fans, but I have my e6400 running at 3.2ghz at about 55C under full load and the room is the warmest one in the house so the airflow is just fine.how is the airflow out of the front of the case?
any more pics with the case filled up but with front cover on? how much clearance did you have for your that cpu hsf? I'm wondering if there's space for any of the 12cm hsf
check sig...
and yes, you should have room for bigger HSF's
