stormshadow said:hmm... just noticed something...
looks like the PSU exhaust which can be quite warm would just float up right into that intake fan and back into the case...
unless there's a barrier on the front cover of the case
The PSU's with the 120mm fan on the bottom.. Are they an issue in this case? Which way are they oriented? I assume they are at least partially blocked by something.
in reference to the PSU... i'm guessing that if you orientate your PSU so that the intake 120mm is on the top, some of the intake of the case (front mounted 120mm) would draft to the intake of the PSU...
chris.c said:Any other questions feel free to ask.
Tutelary said:pics of an assembled system please.
ahhh - gotchakhanable said:that fan is an exhaust
air comes in from the back and out the front
khanable said:Ya, between two people with this case we should atleast get one pic of a fully loaded rig!!
Ockie said:The case is ready for the lian li video cooler unit that vents air outside of the case... but I don't have one of those on hand
RAA-Kr1cH said:I'm not too familiar with their products, so I jumped over to their site, and didn't see anything like this. Could you link this cooler you're talkin about?
aburgard said:More Lian Li innovation... Great cases. Mounting the mobo right side up makes heat pipes work a bit better too. Moving the PSU to the front lets you use an aftermarket HSF too unlike the PC-V600.
Is there definitive proof of that somewhere? I'm not trying to be an ass, but I found numerous sites that say it IS an issue. They're mostly hearsay or didn't have evidence to back up said claims, but even so I didn't find anything to the contrary. I'm curious why you think it's not an issue to mount heatpipes upside down.Ockie said:The upside down heatpipe thing is a myth.
saan44 said:Is there definitive proof of that somewhere? I'm not trying to be an ass, but I found numerous sites that say it IS an issue. They're mostly hearsay or didn't have evidence to back up said claims, but even so I didn't find anything to the contrary. I'm curious why you think it's not an issue to mount heatpipes upside down.
ChrisMorley said:On solid metal heatpipes it is not an issue, but theoretically those heatpipes that actually utilize evaporative liquids should perform sub-par. I do remember Zalman GPU coolers when they first came out had warnings against utilizing the solution in the wrong orientation which would degrade performance.
The last Asus board that we cut the tubing on was solid, though.
ryboto said:I guess you didn't really read that wiki...true heat pipes have a wick which transports the working fluid by capillary flow to the heat source REGARDLESS of the orientation. Heat pipes that lack a wick will not perform correctly when inverted from their originally intended position. Example: the heat pipe on my AT8 northbridge was not wicked and the temperature of the northbridge would get to 48C just idling. Whe I swapped it for my zalman nb cooler, temps dropped back to the 30's. If you cut a "heatpip" and you find that it's a sollid copper or aluminum rod, it's not a "heatpipe" it's a copper rod, there's a difference, and if asus really is uesing solid copper rods, they could possibly be decreasing the heat transfer performance of their cooling system.
stormshadow said:thx for the pics ...
what model PSU is that?
and do i see some kind of spacer / pad btwn the PSU and the front of the case?
ganstafm said:wow good wire management for size
oh. I see.ChrisMorley said:There's a recessed mount for the PSU to allow for the power adapter. It's our branded 500W PSU...
stormshadow said:oh. I see.
this really is screwing w/ my space limitation calculations...
so that spacer is necessary to make room for the power cord correct? and that's supplied w/ the case?
and not to be a pain but do you have the length of the your VM PSU? I need this to estimate how far the PSU will intrude into the case...
thx. Chris.
ChrisMorley said:It's a normal size PSU that should be the same size as just about everything else out there, with the exception of PCP&P and Enermax 1Kw.
And yes, the spacer is included along with the power cable extender...
h41cyon said:I'm really liking the way this case looks!
I might actually end up getting this one for my next build, but,
how would one go about putting a watercooling system into this system? Since the airflow is back to front, the radiator would have to be in the front of the machine.
Is there enough room? does anyone else have any thoughts on this case and watercooling?
what are the specs on this bad boy. i see your using the new 650i asus board, how do you like it?ChrisMorley said:
no it's not. rear fan is an intake.sowingseason said:yuor ac freezer pro is going the wrong way
aburgard said:I traded emails with Asus on their EAX1600XT and Thermalright on their V1-Ultra. Both said NOT to mount them inverted because their heatpipes were not wicked.
Wicked heatpipes like the H3 VGA cooler are fine in either position.
aiya said:what are the specs on this bad boy. i see your using the new 650i asus board, how do you like it?
this case looks good and i'm just amazed at how much stuff you can pack into it. but it looks like watercooling it might be a problem if you wanted it to be completely internal, might have to mod it a little for that. but thats why theres external
stormshadow said:no it's not. rear fan is an intake.
reverse flow case.
