I feel sick...
Status
Not open for further replies.
starhawk said:
i sorta hate to say this... but i concur with dariob.
i further predict that either (a) your response will be a mild flame to both me and dariob or (b) you will not respond at all.
i concur with dariob too
seriously, why bother asking us for help when you refuse to let us help you??
maybe he'll realize his mistake and actually checks his psu
lol
and generic PSU? c'mon, you should know better. well I guess now you do ;)
Can you not read? I said I followed your advice, and yet you continue to flame.
I did. Check last page and you will see I did and came to the conclusion that it was dead. I followed the advice on the sitcking a wire on the green ATX wire and ground ATX wire.
Nightrain said:
I just put together my brothers computer. I went over turned it on and *BANG* a big spark, and it started to smell. OMFG I am going to collapse. :(
One time I installed everything, turned it on, then realized I forget the heatsink. I feel your pain.
i once installed a floppy cable backwards... :rolleyes: that caused quite a bit of confusion for me...
Only once? I've spent 30 minutes screwing with floppy cables flipping them every which way until they work before. That's why I gladly don't put floppy drives in my comps anymore. I hate all cables that don't have the tabs on them to only be plugged in one way though.
Give the guy a break for chrissakes.
The post about him either flaming or not responding is retarded.
What is he supposed to do? Respond that you are in fact the great jedi master, all knower of pc land and he bows to your greatness? Get over yourself. And stop hijacking the dang thread.
Dogpiling is for losers.
He admitted he was fairly noobish and I am sure he wanted to try the free(tho extremely unlikely) option first. He got bad advice from someone he knew yet had enough sense to post here realizing the advice probably wasn't that sound.
If you offer advice and someone doesnt immediately take it just move along. No need to stand in a corner and scream at them.
BTW, get a sparkle/fortron psu. They are cheap and ultra-reliable. And smack your brother for using that case. LOL. :)
I forgot to connect my CD drive to the cable once. Couldn't figure out why Windows didn't want to install for the longest time. My CE friend and I sat there with the case open looking at the CD drive and everything else for 30 min. Finally realized there was no cable.
:D Nice to know we all make these kinds of mistakes from time to time... ;)
Question is though, did this guy ever get his problem straightened out? I didn't read through all the posts since most of it looked "flamish", but based on what I did read, and since there didn't appear to be damage to the mainboard or the proc, I'd replace the power supply with a good one. most likely the whole issue.
Ax
Good news!
I checked my friends PSU (using the Green/ATX + Ground/ATX method) and the PSU fan spun up. Then I installed it onto the system. I only hooked the main ATX connection to the motherboard, and nothing else. Good the CPU fan starts to spin. Then I put power on the DVDRW drive, hard drive, and floppy. GOod. Everything is working nicely. Next I hooked the IDE cables up and hooked the system up to a spare monitor and keyboard. Excellent. I got into the bios and it detected everything. Now I will install XP soon and hopefully this baby can be up and running. The only problem I encountered was in the BIOS; the BIOS stated that the CPU was clocked at 1100MHz when it is supposed to be around 1800MHz. Shouldn't be to hard of a problem to fix as I long as I do it slowly.
I want to thank everyone for the helpful advice, it is greatly appreciated. When I posted the thread I had no hope. I turned on the power and there was a spark, and I did it again and the same thing happened. Now I wasn't looking inside the case (I was in the back) so I saw the general area of where it was but wasn't sure what heppened. So naturally I panicked. Now I can come to the conclusion that the spark came inside of the PSU because of the burn marks inside.
Agains thanks to all.
great job, my friend. you have gone from being stubborn and unsure to being [H]. this deserves a reward of some sort.
Nightrain got 100 kudo points!
I think the real lesson learned here is "don't panic". That just makes everything seem 100x worse than it really is.
Thanks. :)
The major lesson I learned from this is that I will always put a good PSU on top of the list. Even if it is a cheap budget system.
Nightrain said:
Thanks. :)
Also remember, a budget system in time could turn into more than that and having a good PSU in the system could save you money in the long run since you might not have to upgrade the PSU along with other things.
Quality up front can easily save you money in the long run.
Couldn't have said that any better myself. :D
Ax
one of the good things about those kudo points nightrain... they actually are worth something. those 100 kudo points will knock anything in my fs/t thread that is $2.50 down to $1. ergo, 200 kudo points will knock something that is $5 down to $2... and i happen to have a $5 pci game card that might just still work... it would make a nice addition to your comp, i think, even tho it is more than a little old.
djnes said:
Your friend is an idiot if you told him there was a bang and a spark, and he's blaming the thermal pad/paste material.
Actually this could happen. If instead of using Artic Silver 5 he grabbed some Army Surplus C4. Boom, bang and spark. Sorry, I just had to. ;)
Good to hear it was just the PSU. On your next order you might want ot get one of these. Not only starts the PSU but puts a load on it.
that's a cool little whachamadinger...
Keep in mind that a good PSU for a budget or daily use computer doesn't have to be anything very fancy. It's generally more an issue of brand quality than it is buying the biggest baddest PSU from one of the best brands.
Nightrain said:
Good news!
i'm assuming this is the first time you booted up the computer, so the CMOS is "clear" and has no data stored in it. You won't hurt anything by upping the FSB to whatever it is stock.
you know, i got some comic relief from this thread...ahah...lol, sorry to laugh at ur misfortune dude, but thanks to you, my day was a little bit better :D
and TJ (aka DeathMan), you use way too many smilies, and ur never gonna catch up to my post count :p (probly cuz you don't post 24/7 :eek: )
very funny, you (insert random... preferably bad... word here :D )
and i'm not trying to catch up to ur count... i'm just readin the threads
so... u fixed the computer... bravo
Alex41290 said:
jeez, the emotion and happiness is dripping all over.........................as well as the sarcasm :p
actually, i wasn't being sarcastic (for once)
i was complimenting the guy for taking people's advice and putting it to work... so... problem solved :D
well, i was really pointing at the swapping of psu's, not just simply check it... i meant to actually switch it with a working one.... but o well, u got it to work so i guess all's good... so i take back all my words and anything offensive altho i said it to motivate you to swap the psu
congrats! ;)
I think the real lesson here is do NOT use crappy generic PSUs ;)
or listen to the [H] members and don't just repeat the same thing OVER AND OVER AND OVER AGAIN....
he heh....
i like the suggestion of the "steps of [H]" of how to post and recieve help...
very useful in this situation
and... alex... ur on ic... go on AIM DAMMIT!
Mod Edit -
Nightrain said:
Good news!.....Everything is working nicely......I want to thank everyone for the helpful advice, it is greatly appreciated.
Sounds like Nightrain got his issue solved, and I think we'll bid "adieu" to this thread before it wanders even farther off topic......:cool: B.B.S.
Status
