DermicSavage said:where's the carnage?
i want a mobo covered in BLACK
Nightrain said:Well I hope to god it didnt take the motherboard with it. If it did I'm screwed.
-edit-
I was just talking to my friend and he thinks the blame is on the heatsink clay (which is what AMD uses instead of giving you paste) and that it shorted. So he is going to lend me some paste and try that. Man my biggest worry is that the spark/short/spike took out the motherboard. >_<
so_cal_forever said:If you cant find any physical damage to the motherboard, the PSU may have blown a cap. What brand is the PSU?
djnes said:Your friend is an idiot if you told him there was a bang and a spark, and he's blaming the thermal pad/paste material.
iownyou14 said:Take off the heatsink. See if there is any damage. If not, it might be the power supply.
djnes said:I hope it's not the same friend. And one more time for those who are ignoring the previous posts. Thermal pads and paste DO NOT GO BANG! It's absolutely insame to think that swapping new thermally conductive material will fix the problem. Just because you don't "see" damage, doesn't mean something didn't die. The PSU is also a likely cause, but you haven't checked it. Please use some common sense here....do you really think thermal material will spark and make a bang??? Seriously?
Nightrain said:Do you still think I should try and apply new paste? Or remove the heatsink for that matter right now?
DermicSavage said:no
in short your friend doesnt know what hes doing
if there really was a bang, then there would be physical signs of it, and since there is none on the mobo, it is prolly the power supply(ESPECIALLY because it is soem generic brand)
Nightrain said:What if lets say I didn't apply the heatsink right and some of the thermal pad got a bit messed up? Now if that is the case if I remove the heatsink I should see damage correct?
dariob said:I vote that its the PSU. Pop a KG one in there and I bet it will work.
Dario
Nightrain said:I don't have any spare working PSUs![]()
Codegen said:I've never experianced a PSU myself, but when my G/F (not my G/F) had her PSU blowout, She mentioned a big bang.
I had a spare Codegen 300W PSU to try. (hers was an L&C 300W) Started up, she gave me 20 bucks for the PSU, and I went home.
But... What if it happens again, what will I do..........................
Nightrain said:I think it is generic. A brand called "Crion" now I know not to get PSU's that don't have a good name but this isn't exactly a top of the line system.
