Bladestorm
- Dec 10, 2006
If you asked for a refund, the fact that the monitor arrived broken is irrelevant.
I disagree. They sold me garbage. Why should I be out $40?
You haven't had much luck between this and the Samsung have ya?
If they ship you a new unit, do you still have to pay extra $$$$$, or is this just if you want a refund? I know it's a pain in the ass, but I've had to do it twice with NEC screens and it worked out well both times.
I went from the Samsung to this HP, and then back to the Samsung. I've had the 2nd Sammy for a month and an half, and I'm satisfied with it. I'm sure HP wouldn't have charged for shipping a replacement unit(?), but I didn't want to take the chance of having another defective unit.
How would you compare the two and why did you return the Samsung first time?
What?? There are some great TVs you can get for under $1,000 (Panasonic Plasma).
quick update: xbox -> HDMI -> dvi -> zr2740w does NOT work as far as i can tell.
so...
the xbox actually works fine on the zr2740w in 720p. i just needed to reset the display settings on the console.
oops!
also, i'm now getting the weird blinking pixels in the upper right, but only on the displayport input. dvi is fine. it's about 2-3 pixels at the very very edge of the screen that blink depending on how light the rest of the screen is.
weird stuff!
It worked with my PS3 when manually set to 720p as the only output res.
so u use other monitor to hook up ps3 then set ps3 to 720p? which connector wire do u use? i will try again tomorrow
You just need an HDMI->DVI cable, like theis one:
http://www.monoprice.com/products/p...=10231&cs_id=1023104&p_id=2405&seq=1&format=2
Of course, that won't get you audio, at least not on it's own.
I just got one last week. It was a replacement for an Planar 24".Are there more people with this monitor? What are your impressions?
The screen is very bright. I game in somewhat muted color titles so it's not a big deal, but the lack of onscreen controls could be frustrating for someone who does a lot of stuff with bright colors or likes to fine-tune the display for every app they use.
The anti-reflective coating.. hmm.. It doesn't bother *me* but I am fully aware it is there. Not a deal breaker but if it was $100 more I would have expected a less visible AR solution.
Which reminds me, I got a rebate form to send in ahh
- I wish the stand let the monitor sit a *little* lower.
- Dig that it can rotate to portrait, gonna need to try it out with MAME when I get a chance.
- $600ish before rebate, $500ish after? Half the price of an Apple 27". *Motley Crue hand gesture*
- Runs warm, which I expected. Next summer will be interesting.
Im thinking this is the right price point to do something with then myslef..
my badly aging old westy 37 and the creeping blob...getting bad.. and I just cant imagine anything smaller than a 27 having used the 37 for so long. 30's are nice..but significant jump cost wise..and require more gpu pwr.. so..27" looks to be the sweet spot...
practically
How did you get it for 500ish after rebates? i checked a few sites & forums, didnt see anything about a rebate?
http://hardforum.com/showthread.php?t=1659291
The price had apparently been shifting around, I don't know if the rebate is still valid on new orders.
operative word...
meaning a single 580gtx class should be good to run at reasonably high quality settings.. although I understand you were referencing my comparing 27" to 30"... and there not being much difference.. I get it..
obviously, the westy 37 was just a giant 1080p display.. smaller, higher res anything ( with higher res being the important piece ) will require more gpu pwr than I have now.. again, though.. not more than a single 580 class.. I wouldn't think..
Anyone else having problems with blinking pixels, as seen on this video:
http://www.youtube.com/watch?v=Duqq5L46HDw
I've got mine a few weeks ago, and it had blinking pixels in the same location as the video, got a replacement monitor and that one got the same problem.
The pixels are not blinking all the time, only in certain programs, like Google Chrome and Microsoft Remote Desktop Connection, and the problems seems to occur more often if colormode is set to 16-bit.
Im using the DisplayPort.
I am thinking about buying one of these, but I heard that some people could not select the full 2560 x 1440 resolution in Windows, depending on their video card. A review I read on Amazon stated that a 6450 and a 6770 could not do it, but a 6950 could. I currently own a 6850, and I was wondering if anyone else knows whether a ZR2740W can be set to run at 2560 x 1440 with this card.
yes, there's something wrong with the DP interface (is there ever anything right with the DP interface on anything?)I have the same problem at the exact location as well. I tried different cables even different cards but the problem still exists. I believe it's either a bad batch or something wrong with the DP interface. DVI port has no such problem for me.
