No. One HBA per SAS expander.can I use this expander in any way to connect several old Supermicro servers with LSI controllers and 16 disks each to make one SAN?
But I could connect the expander to the PCB in the chassis where you connect all the drives or is that PCB an HBA as well?No. One HBA per SAS expander.
I finally got my SAS Expander and a LSI 3ware 9690SA-4I raid controller which should work according to the compatibility list in this thread.
At the moment I use it for testing purposes on a Supermicro H8DCE, which is an older dual socket 940 board, and I can't get it to work.
The controller works fine, I've tried that individually. But as soon as I connect the expander the system hangs during boot when the controller tries to initialize. I get "Waiting for 3ware controller to initialize" on the screen forever (or at least for 30 minutes, I then ran out of patience).
Since the 9690 already had its most recent firmware I wanted to flash the expander to see if it makes any difference and so I got my SmartArray P410 out. That was flashed to FW 3.66 quickly which HP says is required for updating the expander to FW 2.08.
The P410 as well takes ages to initialize during boot with the expander connected but at least it will get through at some point, taking somewhere between 5 and 10 minutes I think.
Unfortunately the HP Update Tool doesn't work properly, it boots via USB and then stops with a black screen doing absolutely nothing. I will try this in a ProLiant server later, but since that lies on my workbench in bits I will rely on the working hardware for the moment.
The expander shows up in ACU when conncted to the P410 and it told me that it has FW 2.06, so that is pretty recent as well.
So at this point I can tell that both controllers have the recent firmware and the expander has FW 2.06.
Long story short:
1. Is it normal that controllers take ages to initialize with the expander connected?
2. Any ideas why the LSI controller doesn't initialize at all with the expander connected?
3. Are there any other ways to update the FW on the expander?
Thx in advance, any help is much appreciated![]()
@Synergy Dustin - I'd like to buy an SAS Expander from you. What's the procedure? Do you take paypal?
Don't waste your time, he never responds to his PMs nor his emails. I sent one to him back in December and never heard back. Save yourself the PITA and just grab one at the egg.
Still having these issues...
@Dustin: Since you sell those damn things and I think you therefore have quite a lot experience with them, do you think you could provide some valuable information on this issue?
Alternatives for EU buyers(probably not cheaper and probably not latest firmware, but probably easier to order)...but don't have the time to reply to requests to ship outside the US.
The external port can be used as an in or out port.
Expander arrived today, didn't know these came with 4x sff8087 to sff8087 cables in the box, if I had known that I would have only ordered 2 rather than six that I thought I needed.
I wonder if everyone's expander arrived with the cables?
Have anyone made SATA Power -> PCI-E 1x/4x connector finally?
My expander arrived with no cables. The only ones I have are 1M long so it has made cabling a bit of a troublesome task.
My rig is an X8SI6-F using the on-board LSI2008 flashed to 9211-8i IT, dual linked to the SAS expander and using a Norco 4224... will be used for ZFS...question:
Is the discovery error stuff at boot just a bug in the LSI v9.00.00.00 FW? I saw a document regarding discovery errors at boot with cascading setups for other LSI controllers with 9.x firmware. Timeout takes over a minute but does find the drives. I haven't yet tested without the SAS expander connected as it seems to work and I need to get this machine into production ASAP.
