Ports 8 & 9. If I only wanted to do one, I would do #9 but either one should work. They both have a white square around them right on the PCB itself and the white square is labeled "To Controller" whereas the other pairs of ports are labelled "To Drives" (or something to that effect)
Are your drives connected to the sas expander using SFF-8087 to SATA breakout cables or are you connecting the SAS expander to a backplane using full SAS SFF-8087 cables? Also, when your controller boots what FW version is on your HP SAS expander?
I have tried 2 different breakout cables and 4 different SAS SFF-8087 to SFF-8088 cables which connect to my backplane. Both give the same results.
My HP SAS is FW version 2.06. My Adaptec card had an older firmware and I tried updating to the latest. I also tried setting my hdds to 1.5gbps.
Not that this is your issue but I sure hope you actually read through Adaptec's release notes. Sometimes they do scary things with their firmware and the only mention of it is in those release notes. I got burned once.
What backplane are you running it to? What adaptec controller? 8087 and 8088 cables have different pin counts (36 & 26 respectively) 8088 is an external cable and 8087 is internal.
When hooking up your backplanes, begin populating bays attached to the backplane wired up to the SAS port #2.
They cannot be transparent as they must enumerate themselves to the OS to be within the PCI-E spec. They are driverless though and the OS has no control over the expander, only the controller card does.
Your ethernet switch isnt exactly transparent either![]()
The card needs an x4 PCIe slot on a motherboard and draws 11 watts of power. The card doesn't require software drivers, it is invisible to the operating system and motherboard.
has anyone tested the HP SAS expander on the newer generation of dell sas cards? specifically the PERC H700/H800 or the 6Gb/s SAS HBA? I'm thinking Dell 1u server w/ 6Gbps SAS HBA for a cheap head node to a norco 4224 w/the expander...
anything from here? http://www.dell.com/content/topics/...topics/en/us/raid_controller?c=us&l=en&cs=555
I can't think of why it shouldn't work other than it's dell and hp... :-p
I'm planning to buy an expander - just to add more storage to my server (well, what's called server...)
Does anyone of you know, if the Dell Perc 5i oder HP P400 will work with the HP-Card? (I haven't read the whole thread so far)
I'd prefer to use the Perc as it is already installed in my box and the arrays are filled with data, but if there's no other way I could use the P400 I currently use for my SAS-drives.
It could have been so easy... So I'll see, if the P400 works (I hope a friend could test that for me if he buys an expander) or if the next thing on my wish-list is a Perc 6/e.
Yup, the Percs are not perfect controllers - I know that... My 5/i gave me some headache when I used some drives in JBOD-mode, some strange errors while reading files. With the Seagate-drives running in 2 RAID5s everything seems fine.
Configuring the arrays from Windows would not be a problem, as a separate sys-drive is used.
With my 5/i and 5 Seagate 5900.12 I get 330MB/s avg read and 250MB/s avg write (tested with HDTune, 8MB block size), real world was not possible so far, I got no source fast enough... But some Savvios should do that![]()
Why not just get one of the newer LSI cards instead (since that Intel is an LSI card)? LSI 9260 is cheaper and should outperform that thing by a fair amount.anyone know if this expander is compatible with this:
http://www.overclock.net/other-components/942753-fs-intel-16p-sas-raid-card.html#post12495311
cheers!![]()
cheers!![]()
cheers!![]()
just posted an extra HP SAS Expander in for-sale forum. have too many of them now since I've been experimenting with 3 x IBM M1015 cards replacing an HBA + expander with Flexraid 2.0.
is there a lot of difference between firmware v2.02 vs 2.06? Im building my raid right now(areca 1880i)...got 6 more Hitachi 5K3000 coming in this week =D
Edit: I'll check that out site odditory..thanks
I don't see where it says the H800 doesn't support SATA disks and I can add dell SATA disks to an H800 when specing out a new server, ie R510 w/H800 and a dozen 1TB SATA drives...
