@odditory:
Since you seem to got the HP expander working with a 9211-8i controller, did you check the signaling speed between drives and expander? I did try that a while ago and while the controller (tried two different 9211-8i) controllers negotiate 6Gbps with the expander (firmware 2.02), the expander always uses only 1.5Gbps towards the drives. The drives I used were Samsung F1, F3 and also a WD green drive. While one can blame the fan-out cables (I only tried cables from one manufacturer), the controller itself uses 3Gbps when the drives are directly attached. I could never solve this problem, maybe it is just a faulty expander.
I am experiencing issues as well.
MB= SuperMicro MBD-X7DWN+O
Processor= Xeon E5405
RAM= 8GB DDR2 667 FB-DIMM
Raid Card= ARC1880i w/BBU both ports to the Expander
Expander=HP SAS Expander
Drives=
6x Samsung 1TB HD103UJ
3x Seagate 1TB STS31000333AS
10x Seagate 1TB ST31000340AS
2x Seagate 143.3GB ST3146855SSS512
3x Seagate 143.3GB ST3146855SSHPS2
Arrays=
RAID 5 560.0GB All SAS drives
RAID 6 17TB All SATA drives
The SAS array completes fine with no issues and performs as expected. When I add the SATA array things start getting hinky. The array builds after a few days and I begin to run HD Tune Pro on the array. When testing I have 1 or two drives at random drop out and the array becomes degraded. The only way to get these drives back are to reboot the server and add them as Hot-Spares which means a few more days of rebuilding. Rinse and repeat. Yesterday after the latest rebuild everything appeared to be working, even after running HD Tune Pro, so I started the upgrade to the newest firmware. That was successful and again everything looked fine until I started to populate the array with data. The entire HP SAS expander dropped from the Areca card. So I restarted the server and after the BIOS screen I got nothing. I unplug one of the ports to the expander and get to the Areca card and notice that the SATA array is completely gone. At this point I plugged both ports back into the expander and restart. I get the blank screen so I try and pull the battery and see what I can get. I get the Areca screen so I plug it back in and reboot. I finally have the Areca screen with everything plugged in but still I don't have the SATA array. At this point I went a head and left it because I need the SAS array for my VMs.
Is there anything I can try that would make this headache go away? I am at the point that I am thinking of trying the Areca card with the 846E2 I got from Blue Fox. I planned on using it as just a chassis to add more disks to the Areca card.
I've just plugged in my expander card, and can't see any of the disks attached to it. I've connected it to my SASMV8LP using ones of the short cables I used initially to connect the SASMVLP8 to the backplane - are these the right cables to use, or is there some funky crossover cable that I need to use?
G
So guys. I need some input on what motherboard I should use.
Ideally I would like to see integrated graphics, and 3 8x pci-e slots. One for Raid controller, one for SAS expander, one for 4 port gigabit NIC (4x pci-e works just as good for NIC)
I can't seem to find a suitable mobo so any tips are welcome.
Thanks
Do the SUPERMICRO X8SI6-F with a i3 cpu work with ECC memory?
The motherboard will support ECC without any problems, but NOT with an i3 processor.
If you're looking for a cheap platform to utilise ECC memory, then you're probably much better off with AMD hardware, rather than Intel.
Yes, it supports it. It has to be unregistered though. Registered RAM will not work unless you have a Xeon processor.Do the SUPERMICRO X8SI6-F with a i3 cpu work with ECC memory?
@ odditory, domenic, et al.
I received my replacement sas expander card today and it looks to be working fine. I am running 3 different types of drives now with all showing "SATA300+NCQ(Depth32)" (1x SAMSUNG HD154UI, 9x ST31500341AS, 2x WDC WD20EARS-00MVWB0). I did not do any firmware updates or anything to the areca 1880i and everything is exactly as it was before minus the new sas expander replacement. Hopefully I just had a flaky card and nobody else here has to deal with this. The areca mcraid shows - Enclosure#2 : HP HP SAS EXP Card 2.06(16).
Well, thats not what SM says:
SM FAQ
They've been readily available at many online retailers for $300-$400 for about a year now.
@gmitch64: Go back one page and have a look at my post # 1227 and read from there ...
Thats what I get for not reading through 64 pages of posts
