Delicieuxz
- May 11, 2016
*Update
So after messing around with it for hours I have narrowed it down to the Refresh rate not sticking in the settings. After I turned on the computer or after the monitor goes to sleep, I have to manually tell the monitor to use the 75hz refresh rate in the display options. After that the Monitor works with my RTX 2070 in "AMD Freesync On" flawlessly. No jutter or skipped frames while using the pendulum demo or frameskipp website found on blurbusters.
Kind of annoying to have to manually tell the monitor to use 75hz but I guess I'll have to deal with it. Seeing how their are no affordable options for me for a new 32 inch monitor at this point.
Frame-skipping increases as the FPS goes over whatever normal clock the monitor can handle. So, if the monitor was switching from 75hz to 60hz, it should have less frame-skipping than exists at 75 hz. However, resetting the monitor at 75 hz might do something to stop frame-skipping, for all I know, but the hz being at 60 instead of 75 shouldn't be causing frame-skipping.
Thank you I will try these.
Did those drivers help anything?
