i keep telling myself....i don't need this....i don't need this...
then in the back of my head i think i would love to upgrade my e6420. but then i would need a better mobo bc my old p965 asus cannot oc quads at all. so if i am going new cpu and mobo i might as well wait for i5....
remain calm...hide the credit card or something.
I go this in the Chicago location 3.8 - 447 FSB stock voltages. Posts @ 4ghz not stable.
will this processor work with an evga 680i LT SLI motherboard?
thanks to this hotdeals thread, I'm now a proud owner of an E0 Q9550!
soon I'll be living under a bridge, towing around my bad ass pc...
lol. yeah it's a damn vicious hobby that sucks up your money![]()
It truly is a sickness we have for this stuff.
well, these hot deals definitely lessen the blow a bit!![]()
Or make it worse...depending on your level of self controlWhat's the stock voltage on these chips? Can they run at 1.15V vcore? How about at 400mhz FSB? So tempting...
they run at 1.21 - 1.22 stock voltage
they can do 3.4ghz 400fsb on that voltage stable as hell
I'm testing mine right now. So far I can confirm that it does 3.4 at 1.22. I'm testing 3.6 at 1.25 right now which seems fine, but apparently my Asus Maximus hits an FSB wall at anything past that. I tried 3.8 at 1.36 and it just won't boot. It freezes right before the vista loading bar shows up. Anyone know anything about this particular board? I ran 442x9.5 on my e8500 all day long but with a quad it doesnt work. I havent tried much but I'm stumped at the moment.
probably just need to up the volts more. Your motherboard should have no prob getting that cpu to 4.0.
Sounds like you didn't get a very good Ocing chip...
Ooh, I just did a google search and it appears my x38 is the culprit. Apparently with 45nm quads, the max FSB is around ~440. I actually think I have a good chip because I'm running orthos right now at 3700 (8.5x435) and all is well so far. Anyways, I'm gonna pull it out and try it on my UD3P tomorrow. If I hit 4+ on that board, I will put my e8500 back in my main rig or swap boards. I will repost with my results.
Not at all. I see a big difference with mine at 3.8GHz compared to stock speeds.this chip is pretty fast its pretty much over kill just to overclock it
I recently upgraded my videocard from a 9800 gt to an ati 4890 and have seen no fps improvements, leading me to think it's my core 2 duo e6600. Would this CPU be removing my possible CPU bottleneck? Will I see a huge improvement? (my e6600 is oc'd from 2.4 to 3.0 ghz?
Here is the thread with my issue ( http://www.hardforum.com/showthread.php?p=1034315418#post1034315418 )
picked up one to, haven't installed it yet though. Just wanted to know, will my heatsink (Zalman 9700) be good enough or should I go get a 120 ultra extreme?
