I have been researching with no luck. I looked in the bios for additional settings and saw nothing. The light on the usb transmitter turns off as soon as I press sleep. Then under device manager if I change it to not power off the usb when in sleep the setting doesn't stick. The setting to allow it to wake from sleep is grayed out. I then tried to do it manually under the cmd prompt but it says I don't have permission even when I run cmd as an admin. Please help.
have you tried calling gigabyte yet?
Not yet, but in the meantime if someone has any suggestions I would be very appreciative.
Yeah, gigabyte has an utility you can download to keep a "charging" port open, depending on your PSU's standby 5V power.
Can someone please explain the very negative customer reviews of the GIGABYTE GA-H55N-USB3 at Newegg?
Just got my board, really like it - but, what is causing it, and how can it be avoided?
/SWIN
Hi guys, putting together a SFF system in a SG05 and am trying to decide whether to go for a zotac h55itx-c-e or spend slightly more(about 35$) and go for the H55N-USB3?
Should I go for the zotac or the gigabyte?
Will be using an i3-530 in it with a mushkin callisto ssd and will be using the IGP for HTPC duties.
