- Sep 22, 2000
The "reg" is the register, not the voltage! ALl the cards will show "174" since that's the register you're polling. The second number is what shows the ASIC leakage value. The higher that number, the lower the VID of your card may be.
When you unlock the voltage options, the voltage for your card is set to 1175 mv instantly.
To find your default voltage, you need to run afterburner without unlocking voltage control, just unlock the voltage monitoring, and look at the MV while running something light 3d (not furmark).
If you get 1140 mv, then your card defaults to 1175 mv. if you get 1010 or 980mv then it's probably a 1050mv card.
Basically, lower VID cards can NOT run at max CCC settings without increasing the voltage first. ALthough it would be nice to know if lower VID cards can overclock higher at the same voltage compared to higher vid cards.
Interesting and good catch. In afterburner mine read:
GPU1: 1.112 max and .806 min.
GPU2: 1.175 max and .850 min.
Looks as if I have one of each. I can run just short of max ccc settings. I'll unlock the voltage control and see how they do.
***edit***
I just unlocked the voltage control and the max defaults to the lower card's max at 1.112v. Not the higher vid card at 1.175v.
