[H]orde|Stats 3.0
The only other thing I think would be nice is to have the ranking within team somewhere in it. I'm not sure there is enough space to get that in though.
Here's how it works:
When a browser requests your image, it will take the ExtremeOC uid out of the URL and run it against my database. If no results are returned, OR if the results are more than 3 hours old, it will import your ExtremeOC's XML user stats and update the database, then build the image that way.
This way, I don't waste database size by loading ALL records, and the smaller db size speeds it up, as well. It's much quicker in processing time and wayy less strenuous on my server. :D
It would be cool but would overcrowd the image, imo.
test
ignore, hit the wrong button again
hmm, now i no longer have any icon and cant get it to make one.
T-3
trying again
u_115690
sweet! :D
Thank SmokeRngs.
When I first did them I didn't know if having two colours in one [H] would work.
But now that I've seen them in real life I'm happy to say they do.
We need to keep the big
as a prize for the first person to 100,000,000.
Luck..... :D
u_45199
.... "it looks cool too"...
Thanks xENo.
sharp
Test!!
javascript:document.vbform.message.value=document.vbform.message.value%20+%20'\n'; document.vbform.submit(); halt;
test
I click on your link and go to the site, click on the link for tool bar button, using Horde stats, asks for id number? put in place on team and points are incorrect, put in folding name and error, must be a number
wish it would of given me the correct amount, I gained 46,000 points that I didn't produce
Another test.
I've got the link to work :cool:
xENo:- You have extended the scheme to all the numbers above 1,000,000.
I stopped expanding them as I ran out of room on the page when I first did them plus I was running them up in hurry.
So the icons above 1,000,000 where just put in to show the next two sets of colours.
That way each power of 10 has 15 icons, there are no sudden jumps and its nice and progressive.
Thanks for taking the troube to do this.
Luck......... :D
Edit: I use IE and cannot drag & drop the [H]
I use {URL=http://folding.extremeoverclocking.com/user_summary.php?u=?????}{IMG}http://www.mentallyretired.com/h3/index.cfm/u_?????{/IMG}{/URL}
Just replace the ????? with your own number and the { & } with [ & ]
Pasted that into a notepad and now just copy & paste to the bottom of each post.
Another, easier way is to just right click and do add to favorites and select to add it in the "Links" folder to make it appear on the links bar. You may get a warning that you are trying to add a possibly unsafe link, just click ok to add it anyway.
1, the page in the first post of this thread is different than the one linked to in your last post. or was when i was accessing it
2. the number you gave me still does not show up in the address bar of my browser, which is Firefox .9 on SuSE 9.1 Linux.
3. test number three, as the first two opened a seperate page and deleted the post
:confused::rolleyes::rolleyes::eek:
I think I can! Firefox enabled! If I can do it omg Just ask BillR anyone can do it!
You can use it anywhere.
And btw guys, I use firefox exclusively aside from testing. :D
