[H]orde|Stats 3.0
xENo
Edit by DR_K13:
These have been approved, please start using them in place of version1&version2
and everyone thank xENo and Tigerbiten ,they worked very hard on these!
Well folks, it's out.
I've PMed Kyle to hopefully get permission to use these instead of the old ones. Do not use the 3.0 Icons outside of this post until we've been granted permission. I've also updated the color scheme. Special credit to Tigerbiten for the color scheme.
Link removed - These stats are only going to be around till the end of summer or so. Please look up your profile on HardFolding.com for information on how to add a badge to your posts...
xENo, its not woking for me.
this is what I got.
Error Occurred While Processing Request
Invalid parameter type.
The value cannot be converted to a numeric because it is not a simple value.Simple values are booleans, numbers, strings, and date-time values.
The error occurred in /home/httpd/vhosts/mentallyretired.com/httpdocs/h3/qry_doToolbar.cfm: line 1
1 : <cfparam name="url.u_id" default="0" type="numeric">
2 : <cfset littlebuddy=pointCheck(url.u_id)>
3 : <cfquery name="doToolbar" datasource="hardfolding">
Please try the following:
* Check the ColdFusion documentation to verify that you are using the correct syntax.
* Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7) Gecko/20040803 Firefox/0.9.3
Remote Address 69.10.104.71
Referrer http://www.mentallyretired.com/h3/index.cfm?a=toolbar
Date/Time 02-Feb-05 11:00 PM
Stack Trace
at cfqry_doToolbar2ecfm2068202576.runPage(/home/httpd/vhosts/mentallyretired.com/httpdocs/h3/qry_doToolbar.cfm:1) at cfindex2ecfm237396406.runPage(/home/httpd/vhosts/mentallyretired.com/httpdocs/h3/index.cfm:19)
coldfusion.tagext.lang.ParamTag$InvalidParamTypeException: Invalid parameter type.
at coldfusion.tagext.lang.ParamTag.checkType(ParamTag.java:147)
at coldfusion.tagext.lang.ParamTag.doStartTag(ParamTag.java:99)
at coldfusion.runtime.CfJspPage._emptyTag(CfJspPage.java:1871)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:62)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:107)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:43)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:80)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:47)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:35)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:105)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:252)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:192)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:348)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:294)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
I got that error too, in my case I was putting my folding username in the "ExtremeOC ID" field instead of my ExtremeOC number. But when it comes up with the result, there's a javascript error on the page...something seems to be wrong there. However, I can extract my image from the javascript link.
Edit: I guess it's fixed now
Here goes:
u_113991
Hope it gets approved!
hehe... all you have to do is read the text. It tells you what everything is as you do it. The [H] link it provides you is to be dragged to your toolbar, as mentioned in the accompanying text.
hopefully my other machines will start churning out results so this number doesn't look so pathetic
Wait, do we have to add these manually in each post?javascript:document.vbform.message.value=document.vbform.message.value + '\n'; document.vbform.submit(); halt;
[H]
Read the directions, yall....
Simple. You've already chosen the forum software you intend to use this on, and the URL you want the image linked to in your posts. All you have to do now is click the [H] above, and drag it to your bookmark toolbar. Too easy, right?
[H]
EDIT: wtf does it have all that other junk?
[H]
Great effort xENo, thanks for your hard work. Hopefully it gets approved.
The actual stat (number) helps a great deal. That was a concern I had with the old system, the concept was interesting but unless the colour patterns were memorized, how many of us could tell exactly what they represented (granted, it's not rocket surgery).
Testing, Testing.
u_45199
I'm glad you liked the scheme xENo.
It took a while to work out a nice logical one that did not end up either too big or unexpandable because all the colours had been used up.
Luck........ :D
Ok guys, it's official! They're approved!
I am all good with that as long as everyone is on board. They look great.
That was Kyle's response! w00p! :p
Now, who leads the folding team so they can make the call to switch to the new icons and drop the old ones?
Send the Moose in......... :p
Luck....... :D
u_45199
test ?
Edit:
pd, I was having the same probs.... once u get that toolbar icon made, you dont drag it to the message window and then hit submit, .... INSTEAD, you click your toolbar button and it pastes the appropriate text and sends it for you.
For the first time....testing....
Awesome! Now I just need to work on getting more points..... :D
