DarkStryke
- Sep 19, 2001
If it's using a cooler similar to the 690, that would have added like $100 to the cost of the card.
Those generalized statements are all yours. It's obviously not the only factor at play, but large amounts of VRam obviously do have an impact on performance at high resolutions. If you weren't so busy tripping over your own ego you would at least acknowledge that.
6Gb VRam. Ya think?
A 3GB Titan would perform identical to a 6GB Titan if the applications frame-buffer memory requirement stays below 3GB (which 99.9% of the time it does/will).
Hence, stating (smugly I might add):
for the reason why Titan is a high resolution powerhouse is incorrect.
Look's like Titan does better at higher resolutions than lower.
I would wait it out this week and see if NA pricing is revealed and go from there.
But you are missing the point. Titan doesn't perform better at high resolutions compared to low resolutions because of the quantity of VRAM
Having 6GB of VRAM just ensures it's speed doesn't decrease in rare and demanding frame-buffer scenarios.
