GoldenTiger
- Dec 2, 2004
Bench: http://www.hardware-infos.com/news/4223/nvidia-geforce-titan-erster-echter-3dmark-score.html (found by emertX @ XS).
And....
Looks official!
And....
Andrew LB @ XS said:http://www.techpowerup.com/gpudb/b1417/ASUS_GTX_Titan.html
GPU Name: GK110
Process Size: 28 nm
Transistors: 7,080 million
Die Size: 502 mm?
Render Config
Shading Units: 2688
TMUs: 224
ROPs: 48
SMX: 14
Pixel Rate: 51.2 GPixel/s
Texture Rate: 205.0 GTexel/s
Floating-point: 4,919.04 GFLOPS
Graphics Features
DirectX: 11.1
OpenGL: 4.3
OpenCL: 1.2
Shader Model: 5.0
Released: February 18, 2013
Bus Interface: PCIe 3.0 x16 ?
ASUS Part #: GTXTITAN-6GD5
Clock Speeds
GPU Clock: 915 MHz
Boost Clock: 1019.5 MHz
Memory Clock: 1502 MHz (6008 MHz effective)
Memory
Memory Size: 6144 MB
Memory Type: GDDR5
Memory Bus: 384 bit
Bandwidth: 288.4 GB/s
Reference Board
Slot Width: Dual-slot
TDP: 235 W
Outputs: 2x DVI
1x HDMI
1x DisplayPort
Looks official!
