dandragonrage
- Jun 5, 2004
Why are there just DVI+(mini)HDMI models?
There's a Zotac one with it apparently though but it sucks according to Anand. Is it not worth waiting for better brands? Won't happen?
It doesn't have one. We might see an AIB card with it, but I wouldn't count on it. Display Port simply isn't popular enough yet. The only reason AMD went that route is likely due to wanting to support Eyefinity on a single card and adding another DVI/HDMI port wouldn't be feasible.
is there an advantage to a displayport? seems like a disadvantage to a lot of people
GTX 460 - where is the Displayport?
I haven't seen any NVIDIA cards with a DisplayPort yet.. do they exist?
Yes, they are available on the Quadro line.
Wasn't able to display 2560x1440 on DVI, works like a charm with DisplayPort.
You guys don't like Displayport?
That's the primary reason but AMD has publicly supported DisplayPort standard before Eyefinity, and it showed up on a few of their consumer level cards. AMD, Apple and Dell are actively promoting it.
There's several advantages to DisplayPort. It can carry multiple display streams over one cable enabling you to daisy chain monitors or have multiple DP outputs from one port. For example there is a single DisplayPort -> 3x Dual link DVI adapter in case you have a small laptop with only room for 1 port but want 3 monitors hooked up..
It also can carry secondary data streams such as USB or audio streams. You could hook up a monitor with a USB hub and speakers all with just 1 DP cable.
DisplayPort uses a single clock for all its video streams and can drive a panel directly, reducing the cost and size of both GPU's and display panel logic boards. Remember any die space you free up by dumping RAMDAC/TDMS generators you can replace with shader cores for faster GPU's, and smaller logic boards means thinner displays
It also is a royalty free standard. Any device with an HDMI port has to pay a small fee per port.
