http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=FM35BWT
Become a pirate radio station! This'll cover a solid 5 mile radius.![]()
5 miles? Does the fear of the FCC banhammer come included, or do you have to pay extra?
Archaea, mine keeps restarting when I try to play mp3s recorded at 192. What are you recording and playing your's at?
I have an iPod Video 60GB with tons of mp3s and none of them were encoded by iTunes. Most are ripped using CDex. I've had zero problems playing them on my iPod. Actually, I've had zero problems with my iPod as well.
YMMV, as always with electronics.
I'm willing to bet your playback problems stem from the encoding and not your iPod.
I've seen one in person, I thought it was garbage... I didn't like anything about it... the navigation/menu system was retarded... and it was SLOOOOWWww
Yup, it was the rate. It doesn't like music encoded at 192. I burn a few at 44.1 and they work.
wow.. the glacier can be had for 30 buxx BIN on ebay.. WTF, why are these things so cheap?!![]()
My 2 GB Glacier broke after about four hours. No drops, hard shaking, or anything.
wow nice pics. wish mine was like that, mine is stuck on the hour glass ....
It gets stuck on the hourglass icon(no animation) from the start. From other posts I've read this has happened to alot of people and the fix is either buy a new battery which MIGHT work, or send it back at your expense. Either way, $$ outta my pocket.
I don't know about their customer service...
I ordered a Full Metal Platinum 1.8 2GB and a Glacier at 2GB. I followed these instructions as mentioned before to check if you have the correct amount of memory and to aid in crashing, etc. The FMP checked out fine, but my Glacier ended up having 103MB!
So I guess I am one of the few that are having problems, so I e-mailed them saying that I have read others have had memory issues, so I checked and I have a memory problem too; please send me an answer on replacing my unit or refunding my money. Well, they replied, but I don't think they understood my problem, even though I thought I spelled it out. Here is my e-mail, and Uxcell's response:
Hello,
I have recently purchased item # mv0blk2048mp039 the, "Glacier - MP4
Player 2 inch TFT LCD 2GB Black (using Nokia Battery)"
I formated the drive with the included software like it was recommended to me
from a friend to make sure that I had the correct amount of memory that I paid
for. Well I followed a format procedure and found that I DO NOT have the
correct amount of memory that I paid for! More specifically, the unit says it has 102M.
I would like a replacement sent or a refund immediately as I have read that
this is not an isolated incident and many other people are finding out they
have "hacked" players. Please get back to me ASAP on how you are going to fix
this problem. Thank you.
RESPONSE:
Dear customer,
Each folder can only save 99 files even there is memory left, so please check
whether you have saved more than 99 music files in one folder or not, if yes,
please try to separate those files into different folders, the problem should
be solved. Besides, all the folder should be created under the root
directly and no sub folder should be created. Please kindly have a try and advise.
Regards
uxcell customer service
Well, judging by the manual, their English is not the best (Random quote from manual, "...Go with the following steps to have intercept to have sequence Input intercept in intercept speed..."
I guess I will have to try again and use different wording? At least the FMP 1.8 is sweet. Its feels a lot more solid then the Glacier, but I guess that is because its metal shell. I guess I am off to reword my e-mail...
Just received my glacier yesterday. All in all I say it's worth $50. The FM transmitter works good. Sound quality is not bad either, but DO NOT use the headphones that come with it. There's so much sound leak that my wife could hear it across the room.
One major thing I do not like is menu navigation speed. It takes 2 seconds or so to select something or move around in the menus.
I've seen this same response from Uxcell from others who said they emailed them and got a useless reply.
Basically they either had to reply back to them a couple times before they got anything or else go to www.mympxplayer.org and send a PM to Keith. I've seen people have good luck after contacting him.
Was the email you sent to Uxcell to [email protected]?
Anyone purchased one of the Black Hawk players yet? If it plays videos at a decent frame rate and actually plays NES games I think I might buy one.
EDIT: Found a new coupon code KZATZP78CG The site I got it from says it expires on the 31 of March.
EDIT: Found a great site with some info on generic players and a comparison of the players offered by UXcell http://www.freelabs.com/~whitis/media_players/media_players.xhtml
