Mark Rejhon
- Jul 6, 2004
I'm quite interested if this remains true with LB.Then you should run away screaming from the BenQ since it has worse colours and more ghosting. It is very unlikely that you will not notice the BenQ's AG coming from the glossy VG236H.
I'm thinking future testers now need to test both LightBoost and non-LightBoost for ghosting effects.
We need to compare ASUS non-LightBoost to BENQ non-LightBoost (more ghosting on BENQ)
....OR....
We need to compare ASUS LightBoost to BENQ LightBoost (near zero ghost for both)
I've heard at least one report that the BENQ might have less inter-frame crosstalk than Asus, during the LightBoost strobe mode. I'm not sure if this is applicable to the XL2420T or only for the XL2411T.
There are many scientific reasons why enabling a strobe backlight (LightBoost) can potentially cause the tables to turn; this is because the strobe backlight hides most of the "pixel persistence curve" -- thus, possibly erasing the "bad part of the curve" from being visible to the human eyes.
For an example, see this high speed 480fps YouTube video of LightBoost showing how the vast majority of the pixel persistence curve is hidden by strobing. (backlight turned off while waiting for pixels to transition).
Can someone who also has an ASUS VG278H/HE (or have used one), test the BENQ XL2420T with and without the LightBoost zero-motion-blur tweak? (Forcing LightBoost to be enabled in 2D).
My BENQ XL2411T should arrive within 3-4 days, so I'll be able to test them actually side-by-side.
Thanks,
Mark Rejhon
BlurBusters.com Blog -- Eliminating Motion Blur on LCD's
