any chance for comparison with the previous model 2410T? worth the upgrade?
actually i pretty happy even with the 2410t,i prefer to wait for 120Ηz IPS.
I love this monitor so far. I've had it for 4 days now. Share your settings with me please. I am not sure how to correctly setup the settings.
The image shows the effect of matte coatings on pixels. The S24A350T and FP241W are semi-glossy like the Samsung PLS and Samsung/BenQ VA panels. The NB x201i also uses a lighter matte coating.
The BenQ uses medium AG, which looks just like aggressive AG on the rest of the display up close. It's the same coating found on many TN panels. IMO the BenQ is too grainy just like most Samsung TN's but I was not planning on keeping it any way.
Mine has 1 dead pixel in the center of the screen and I didn't see any noticeable bleeding with the bright default settings. The gamma was really washed out and there was a slight purple-ish tinge.
I have taken pictures of the 60hz and 120hz PixerPixAn performance, which I will upload later. It performs like a 5ms TN @60hz with the AMA off and with AMA ON there is some overshoot (bright shield or halo forming around moving objects). @ 120hz with AMA off there is light-medium streaking and light smearing. With AMA On there is some overshoot (bright shield or halo forming around moving objects) but I have only tried out 2 games.
I have started making my written review here
http://wecravegamestoo.com/forums/e...2420t-120hz-3d-monitor-review.html#post780110
My HDD died so I can't measure the colour presets yet since my basiCColour 5 program is licensed to my old HDD.
NCX - your 120hz ghosting results need redoing. If you look top right it shows 60fps.
I just set three of these up tonight, using two AMD 6970 cards. I have two plugged in via dual link dvi and one via a Displayport cable... I have all monitors plugged into one of the 6970s
Hey guys,
I'm currently building a gaming pc, and am interested in doing 3d surround with three of the XL2420T's. I bought a GTX 690, and there are 3 DVI outputs and one mini-DP. All three DVI outputs are dual-link, however two of them are DVI-I, and the other is DVI-D. If I am wanting to run 3d surround, can I use all three of the DVI outputs, or will I have to use the two DVI-I's and the mini-DP? I guess I'm not certain if the DVI-D is capable of running 120hz on the XL2420T. Any feedback would be most appreciated. Thanks!
Can anyone confirm if they have the same thing happening to them or not? when I turn the computer on after Bios come and goes, windows Animation logo show up and right after it disappears monitors kinda looses signal for about 10 sec or so and i can hear the log in sound from windows then screen comes back on with the input information again....
could it be the TX model? i've sent it back to amazon for replacement since it had problem with built in IR emitter as well, if the new one has the same issues I probably gonna just go with the T version since I almost never play games in 3D....I do not have that problem. I see splash screen then windows loading screen. No black screen/signal loss.
What I was not able to figure out yet is are ALL of them broken or it's only a batch.The TX is completely broke't as far as wireless emitter. I believe it works fine with the provided USB though.
