Good Modular PSUs
Gh()st
I read the sticky above, but I didn't notice any mention of a good modular PSU. Are there any? I've got a Vantec Stealth-520A that's just too big for my clear mid-tower case. Added to that, the things got enough connectors to supply power to another computer!
I'm thinking about selling my PSU, but I want to buy something that's modular, and will give me the flexibility I need. Anyone have recommendations? It needs to have SATA, but I'm not really concernd if it has LED fans (or any other gimmicky add-ons).
My other option is to bust out with a sleeving kit, and cut back some of the extra/unused wiring/connectors. I'd hate to do that to a good PSU, but it's causing an issue that I need to address. ( I have to leave the case side open, and let the unused connections dangle out.
Here are my specs:
Abit IC7-G
P4 478 3.0c (30 capper with Hyper 6 heatsink)
1GB Mushkin Level II 2-2-2 PC3500 (4x256) in dual channel mode
PNY 6800 ( fully unlocked to 16x1,6vp )
2 60GB Maxtor SATA HDD in a Raid 0 config
1 NEC DVD-R/RW
1 NEC CD-R/RW DVD
No experience with them, but i heard that the antec neopowers are good. (not sure which wattages). While some may not agree, i would recommend an ultra x connect 500 w. My friend has one and its never given him a problem. On top of everyting, it looks great, especially once you throw a uv light in your case.
I would not recommend an Ultra. No offense to dude with some crappy 450w ;)
The good modulars are teh Antec Neopower, OCZ Modstreams and possibly the SuperFlower Plug-N.
Use the search feature Luke........
Yeah I thought about the Ultra's, but I keep seeing a lot of people saying they are P.o.S's. I saw a NeoPower the other day at Fry's and thought about picking it up. Never heard of the OCZ or SuperFlower. I check those out.
Thanks for the help! :cool:
What's wrong with the Ultra's? I've had a 500w for months now with no issues and rails have been rock stable under all conditions and there have been no negative reviews AFAIK.
Devil Advocate hat: There are two bad Ultra reviews. Maximum PC did a power supply shootout and Trusted Reviews power supply shootout and in both, high-profile reviews, the Ultra failed catrastrophically.
That, and Powmax is one of Ultra's resellers; so a lot of people have this misconception that Ultra power supplies are made by Leadman, thus adding insult to injury. ;)
All that said, the Ultra passed all of my load tests (twice, even,) the two different resellers that I have worked for over the last three years has sold the product line and have had no real issues with them and I personally have two of them. One as old as a year and a half, and I've had no problems.
So... I could say I suggest the Ultra, but given the climate of this audience; I'm going to suggest the Modstream because I do not recall many reports of failures, nor have I had one fail myself. :D
well, yesterday my "some crappy 450 w" just stopped working. Out of nowhere. So, today i went and got a neopower 480. Get this, and not the ultra. Sure, the ultra looks cool and all, but this is great. And i only had it for one day. Just get a neopower and be happy.
Spectre said:
Actually the misconception was that they were made by Powmax...when they were in fact made by Young Year according to their UL listing :p
Right.. But Powmax ISN'T made by Youngyear. That's the point. ;)
Powmax is just a reseller. Powmax branded power supplies are made by Leadman. So to misconceive that they were made by Powmax would be the misconception that they were made by Leadman.
jonnyGURU said:
Powmax is a reseller. Powmax branded power supplies are made by Leadman. So to misconceive that they were made by Powmax would be the misconception that they were made by Leadman.
I don't remember seeing anyone (here anyway) say they were made by Leadman....they may have. Everyone I remember said they were made by Powmax.....which is incorrect also technically I guess. Then again with PSU's it is such a PITA to try and seperate rebrands, from non since very few people actually do make their own PSU's. IE people quite often say an Antec PSU when really it should be a ChannelWell if we really want to be super PITA's about it.
Oh and pppppppbbbbbbbbbbbbbbbbbbbb..........check my post you quoted again. Ha! Edit things while I post will you....two can play that game :D
I did it just to be clear who I was speaking of.....
No, I saw the UL listing edit. That's cool.
I took out the "XCio made by Antec" analogy because I used the word "ignorant" and so many people mistake that word to mean someone is "stupid." ;)
Here are the modular PS's from PC P&C always #1 :D , on down to more affordable models.
#1
$319 & Shipping > 5 Year Warranty
PC Power & Cooling Turbo Cool 510 SLI
Series Modular with PFC TURBOCOOL510-M/SLI:
DC OUTPUT
+5V @ 40A
+12V @ 34A, 38A pk
-5V @ 0.3A
-12V @ 2A
+3.3V @ 30A
+5VSB @ 3A
power<510W
peak power<650W
http://www.performance-pcs.com/cata...=1735&osCsid=dba2442d0c5111f5ec79e557c87df484
#2
$129.99 & shipping
Hiper Modular Type-R 580W Power Supply (630W Peak) SLI Ready
+12V1@18A, +12V2@20A
http://www.frozencpu.com/psu-163.html
#3
$100.50 & shipping > 3 year warranty
Antec NeoPower 480 watt
120mm fan ATX 12V v2.0 power supply, Active PFC, Model "NeoPower" -RETAIL
Model# NeoPower Item # N82E16817103924
Specifications:Type: ATX
Maximum Power: 480W
PFC: Active
Hold-up Time: 20ms at full load
Efficiency: 70%(min.) at full and typical loads, 115V/230V AC 60/50Hz 60% (min) at light load
Over Voltage Protection: +5V trip point < +6.2V, +3.3V trip point < +4.1V, +12V trip point < +14.3V
Input Voltage: 100V AC to 240V AC +/- 10%
Input Frequency Range: 47Hz - 63Hz
Input Current: 12/6A
Output: +3.3V@30A, +5V@38A, +12V1@18A, +12V2@15A, -12V@1A, +5VSB@2A
MTBF: 80,000 hours at 25°C
Approvals: TUV, UL, CUL, CE, CB, FCC
http://www.securemart.com/cgi-bin/f...id=i24ZyeES&mv_pc=327&mv_specials=&mv_stock=y
#4
$66.99 & shipping > 3yr warranty
Antec SmartPower 2.0 SP-500 500W
+3.3V@32A, +5V@35A, +12V1@17A, +12V2@19A, -12V@0.3A, +5VSB@2A
http://www.costcentral.com/proddetail/Antec_SmartPower_20_SP_500/SP500/F09966/
#5
$99 520W & Free Shipping > 3 Year Warranty
$75 450W & Free Shipping > 3 Year Warranty
OCZ ModStream 520W OR 450W
Power Supply with OCZ EZMod technology, SATA Connector,
Model# OCZ52012U Item # N82E16817104155
Specifications:
Type: ATX
Maximum Power: 520W
Input Voltage: 95~132Vac / 190~264Vac
Input Frequency Range: 60/50Hz
- 520W: +3.3V(28A), +5V(52A), +12V(28A)
- 450W: +3.3V(28A), +5V(45A), +12V(26A)
Approvals: TUV, UL, CSA, CE, CB, FCC
Features: 3 Year warranty, Supports ATX/BTX/PCI Express/SATA, OCZ PowerWhisper Technology with 120mm fan
520W: http://www.monarchcomputer.com/Merc...ode=M&Product_Code=100162&Category_Code=pscat
450W: http://www.monarchcomputer.com/Merc...ode=M&Product_Code=100176&Category_Code=pscat
In my opinion the $67 Antec SP2 500W represents by far the best value.
Dave ;)
Hiper Type-R selling power supplies now? Oh jeez.
I like the coax, but who actually MAKES that power supply?
Whats the low down on this psu? Cant help but feel some de ja vu ( Ultra X Connect)..
I have never even seen one, however my friends in the UK & EU love the Type R 480W & 580W's. ;)
Google for reviews.
jonnyGURU said:
You know that guy couldn't have plugged in the 2x2 in that board and therefore was only using 12V1. ;)
That also means his CPU was only loading the 5V. :( Which would explain why the 12V rail didn't fluctuate much. Oh well.. Maybe I can convince someone to send me a review sample. :D
Hey he is just a kid :rolleyes: , but these are real:
There are 6 reviews here: http://www.amdboard.com/psu.html
I saw those too (the four that were in English and not a dead link, that is.).
I think I'll wait until someone loads one up with some equipment. I think I know somone that knows someone at FrozanCPU, so I'm going to see about working out some sort of a deal. ;)
AFAIK FrozenCPU is not an "official" Hiper dealer ar this time.
Oh.. Well, now I'm confused. I see the status for the item is "Not In Stock." Did they never have them in stock? I guess they're just waiting to import them in or something?
Oklohaoma wolf had at one point nailed some of their supplies as being
Fore Point Industrial but he didn't know about this one.
Yeah.. I've never heard of Fore Play Industrial either. I'll have to research this beast.
The Fore Point UL file number used to be all over units from both Hiper and Superflower/TTGI - I'm just not sure yet if either have changed OEM's or begun making them for themselves. I've also had a suspicion for a while that Enermax fits in there too somewhere in the past.
Edit - I think you nailed 'em Spectre - that's gotta be Fore Point ;)
The one I listed doesn't fit a SuperFlower (I believe) but if you follow the link I posted there appears to be a picture of a SuperFlower there under the Plug-N's. So they may still be.
Edit: though these have to be some of the crappiest pics i have seen in awhile.
Spectre said:
SuperFlower Plug-N.
mine has started to fail after roughly 5 months of use. my aspire psu on the otherhand, has gone for a couple years w/o problem.
we'll see how TTGI is with their warranty service now :)
How has it "started" to fail?
Funny thing about computers...
I've always had computer components either fail.. or not fail. :)
Unless you're talking about a fan or something. ;)
I had a 20GB WD HDD that "started to fail" allowing me to backup everything before it failed completely,
but I've never had a PSU "start to fail", what is it doing wrong?
I had a 20GB WD HDD that "started to fail" allowing me to backup everything before it failed completely...
Yeah. I was generalizing. Let's just say "things with moving parts" can start to fail, but that's about it. :)
Some might say leaking caps are a "starting to fail" situation, but if the cap's already leaking... I think it's already failed. ;)
errrr..... :p
well actually this forum fed the Powmax\Leadman flames quite heavilly, in fact its just possible we where the driving force behind the misconception as the Powmax listing was spotted here almost immediately and jumped all over and widely distributed, and further that stance was rigorously defended until proof otherwise was forthcoming
however once provided with enough clues by Ultra I personally uncovered the Youngyear attribution from a lead in one of their manuals which I was able to match up to the UL database and publicly ate my own words :p
luckily for me most of the truely nasty invective on my part is hard to find as its attributed to my even twin Ice Czar Guest :p
so much for my confession, ither guilty parties will have to come forward themselves
I would point out Ive mellowed (if you can call it that) since being made an Admin :p
Powmax is a wholely owned Leadman subsidiary BTW
I can vaugely remember yelling something about Ultra being Powmax crap or something to that effect
:D
oops
Ice Czar said:
errrr.....
Right my point from the Previous post of mine (above the one quoted) were people were running around saying Powmax was making them not at least attributing them to the parent company (leadman) that does the actual dirty deed for Powmax.
:p
I have had my superflower Plug-N for 8 months now no problems. Silent (14cm led fan), 550w (there is also a 450w version), and overall performs great. Just look at the stuff im powering with this thing.
