Firstly Thanks for this great guide! One of the best ive seen on the web ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Overcloking is something that untill about a week ago never really interested me, to be honest ive never really needed to overclock....then Crysis was released![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This game will in the end drive me insane, a few days ago I OC'd my 8800GTS to 600/1389/1003 and was finally able to play with a decent frame rate....or so i thought, seems it wasnt quite enough in large gunfights or anything making intense use of the physics engine so as stubern as I am, I decided it was time to push things more.
my system: 965P-DS3 - E6600 - 4x1GB OCZGold Dual channel - 8800GTS 640Mb - 74 GB 10000 RPM WD Raptor (system drive) - Audigy 2ZS - Vista Ultimate 32bit.
I've spent the last two days reading this Thread when I've had time, and tonight I decided to go for it. After much thinking of a good starting point I decided to go with the following...
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster___________ [Auto]
CPU Clock Ratio (Note)____________ [8]
CPU Host Clock Control_ [Enabled]
CPU Host Frequency (MHz)__________ [400]
PCI Express Frequency (Mhz)_______ [102]
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ [2.0]
Memory Frequency (Mhz) 800
DRAM Timing Selectable_______ SPD __ [Manual]
CAS Latency Time_____________ 5 ____ [5]
Dram RAS# to CAS# Delay______ 5 ____ [5]
Dram RAS# Precharge Delay_____5 ____ [5]
Precharge Delay (tRAS)________15 ____[15]
ACT to ACT Delay (tRRD)_______4 _____[auto]
Rank Write to READ Delay______3 _____[auto]
Write to Precharge Delay______6 _____[auto]
Refresh to ACT Delay________42 ______[0]
Read to Precharge Delay_______4 _____[auto]
Memory Performance Enhance__________ [Normal]
High Speed DRAM DLL Settings________ [Option 1]
******** System Voltage NOT Optimized ******** <<---IGNORE This.
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [+0.200V]
PCI-E OverVoltage Control_ [+0.1V]
FSB OverVoltage Control___ [+0.1V]
(G)MCH OverVoltage Control [+0.1V]
CPU Voltage Control_______ [1.375]
I'm now Running at 3200Mhz (8x400) With what seems like no issues, was the first ry as well which amuses me, beginners luck I guess Temps are warm under Load (58) but I'm looking at upgrading cooling as soon as I've finished this post.
all in all I'm fairly happy, orthos has been running for just over 1,5 hours now, and I got 2 hours out of crysis earlier but then I crashed, although that means nothing as its was crashing occaisionally before the OC as well.
Should I try to tweek the ram more? I have no need really and at the moment things "seem" stable.
also why do some apps show my fsb as 450x8 and the cpu at 3600Mhz![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
http://avatar-its.de/screen_oc.jpg
