Boil
- Sep 19, 2015
You could always set up a dual boot, OS X or Windows; Hackintosh it...!My days using MacOS are about to end soon!
sameJust backed it again *cough*![]()
I search for Kickstarter Link to and inShould really turn the "It's Live" text on your webpage to a link to the kickstarter. Very confusing to find if you don't get the e-mail.
Believe you could, Jay is saying hes going to do exactly that.I wonder if you could do a rad on the bottom to cool gpu and rad on top for the cpu(x2 hats), or vice versa. Would be like a little m-atx case.
apparently you can, which is what Jay said he's most likely going to do. When you keep adding on these top hats though, I'm kinda wondering when you leave "SFF" territory and enter NZXT manta ITX territoryI wonder if you could do a rad on the bottom to cool gpu and rad on top for the cpu(x2 hats), or vice versa. Would be like a little m-atx case.
THE real question is can you stack the Ghost S1 on another Ghost S1! Haha
Large Top Hat
Ghost S1
Small Top Hat
Ghost S1
Large Top Hat
Btw i m not sure about the goal..dan had a much lower goal for both their kickstart
Really hope soIt's probably related to MOQ (minimum order quantity) - the manufacturers usually offer a better per-unit price if you order more than a specific amount. A lower MOQ would mean a higher per-unit price. It could also be a hard MOQ, i.e. the manufacturer won't even accept the order at all unless there are enough units ordered.
I personally don't think it's high, and neither am I worried about the Kickstarter succeeding. I'm confident it will.
probably no, would be fun to see someone do the modWill you be able to screw that middle small hat to both frames? I mean is there a way to access the screws from both sides?
Louqe have replied to someone's question in the KS comment section with the following:maybe if more reviews are published soon the goal might even be reached in 24 hours, 7 hours left.
"There are many add-ons in the pipeline, glass side panels, handle TopHat, ODD TopHat, I/O TopHat, carrying cases, joiner Hats etc... first we need to get the platform out, then many options will be available. With enough funding we will be able to kick those projects off right away!"
So sounds like it's being planned and i love the idea of a carry handle top hat![]()
It's now at 75% and still not even a full day.That is what I like to see! I've changed my hopes for the KS, I hope to see at least 2000 backers so the add-ons come to fruition.
I hope it now doesn't simply stop like the original campaign and that JayzTwoCents's video gets some new folk to back it.
I was expecting JayzTwoCents's to have a complete build video. He didn't have a PSU, so we did not see a complete build at all![]()
My interpretation is that it was just a preview video, and there will be another video with hardware mounted and running?
Yes, he'll do another video with his "balls to the wall" build![]()
Since we're on this subject, do you know why he showed a Titan X instead of a 1080ti?
Isn't the 1080ti slightly better?
Also, at about 8:25 he said that a blower style GPU is preffered? Why is it?
I was thinking about this. I backed and got a Sentry case from SaperPL & ZombiPL. In their thread some people have used foam to create a funnel for GPU or CPU fans up to the grills on the case. Maybe with the side grills something like this would help the non-blower style cards.Well for any SFF case exhausting air out the back is idea. Using a open air style GPU will saturate the interior of the case with heat which in-turn will rise CPU temperatures. I will wait to see Jayz2cents "balls to the wall" build and maybe he can sqeeze that kingpin 1080ti in there. If he can and prove low CPU temps (without AIO) then I may consider sticking with an open air style GPU.
A blower focuses the hot air out the grill of the card rather than spread it around the inside of your case.Since we're on this subject, do you know why he showed a Titan X instead of a 1080ti?
what will the retail cost be?
