I still make more money LTC mining with dual 7950s.
1200 KH/s gives me $700 projected profit per month
What settings do you use? For the life of me I can't get a 7930 (tahiti le) card to do more than 330 KH/s.
Mind PMing me a litecoin for dummies setup for 7950? No idea where to start.
Grab GUIminer scrypt: https://bitcointalk.org/index.php?topic=150331.0
I use the 7950 High preset with reaper
It's not much different than Bitcoin. Just download the miner I linked above and point to an LTC pool of your choice.
To generate a wallet address you can download the official client at http://litecoin.org/, works just like Bitcoin.
I tried that earlier today. Granted I don't have a 7950 but a 7930 (sort of) so maybe I can just adjust the settings proportionately to the number of shaders. Did you touch the clock speed/memory at all? Still, I'd think I'd be able to do better than just about half what you're getting per card.
Damn, the upcoming difficulty bump is really gonna hit the profit margins. Allchains.info is estimating an ltc bump to 241, a 17% increase . Going to kick in just in time for me to get my mining rig up and running...FML...ltc values need to kick up a couple dollars damn it.
Nothing like having 4 Titans hashing...........at 500kh.
Only Avalon delivered a product. Those with Avalons are making over 10 grand a month of 650 watts. If you have an ASIC now, you are making big fucking money. But hey, I could be wrong, Butterfly might come through one of these days and ASICS will dominate mining and the 5870's will drop back to their real value. Its bound to happen soon, and bitmining will become a future benchmark when comparing ATi to Nvidia cards.
Mining LTC with my 7950 at 640mhash. Fun. Is there an exchange anyone can recommend? Do you have to convert LTC to USD then BTC or is there a direct exchange?
If ASICs went mainstream and everyone started using them, the end result would be an extreme increase in the price of electricity, to the order of dollars per kilowatt hour instead of pennies. I don't need to describe what kind of apocalyptic havoc that would wreak on the world economy, because it would never be allowed to get to that point. Since the price of electricity cannot be allowed to go up sufficiently high to make bitmining no longer worthwhile, the only other options are to reduce the value of bitcoins or increase the difficulty of mining them.
By any means necessary.
Are you overclocking your 7950? As far as exchanges go, I am using btc-e.com to convert to usd or btc. You can then send it over to MtGox and then send it to dwolla for withdrawal. There isn't a simpler process unfortunately, at least not that ive found.
Yes. 1000/1700 @ 1.1v. Holds 68C mining. Desktop is laggy as heck while using it, though. I am using the give me ltc mining pool but my issue is my hashrate via the guiminer interface is 640 while my actual speed accoring to the pool is~500. Points seem to verify this. Is there a way to bump that up a bit?
Sounds like your just getting hit with stales. I report a stead 1.4 in guiminer but I fluctuate between 1.2 and 1.6 on coinotron...just the nature of the beast I guess. Maybe try upping the voltage a bit see if that helps, your OC might be slightly unstable.
I think people expecting a consistent $350 a month per 7950 are counting their chickens before the egg is laid. Yesterday's LTC diff increase reduced coins per hour by 14%, and that's going to keep happening until profit margins fall and people quit mining.
Why on earth would a company ever sell an ASIC that effective at bitmining? If you could build such devices, you would keep them and use them yourself.
So I was running guiminer-scrypt coinotron all night, it was going at 675 khash and coinotron reports looked good, other then it reported a 100 lower khash or so. At one point in the night I looked and guiminer said like 500 shares, dozen or so stales. My card was running full load 80-85C. 1135/1675 -20 board power @ 1.25v (may of been 1.2v) When I got up I found that the PC was frozen and after rebooting and checking coinotron.com it said I only got .5 LTC so far, but was expecting more from their estimate. I'm using Trixx to overclock because I have problems with MSI Afterburner. I try using less voltage 1225, 1220, 1150, etc. but they don't seem to be stable. I keep trying different clocks and either freeze up immediately or unstable. Trying 950/1460 @ 1.2 which works so far but it getting slower khash. Says 500 khash and coinotron is only reporting 80khash. Man this stuff is a pain.
What's the best reaper setup? I keep jumping between guiminer default 7950 high/low which reports higher in coinotron then reaper 7950 proxied setup and only on high and hot overclock does it seem to achieve 650+ or 550+ in coinotron. I have been using the GUI reaper, but now that I'm using proxy script + reaper standalone script, coinotron is reporting 550khash with my underclock. But it often goes down, and I see alot of stales eventually and have to restart script.
My goal would be to get 200$-/+ a month from mining LTC 75% of the time and achieving less then 80C temps but around 600-650 khash
cgminer.exe --scrypt -o stratum+tcp://coinotron.com:3334 -u [username] -p [password] -o http://pool.give-me-ltc.com:8080 -u [username] -p [password] -d 0 -w 256 -v 1 -I 11 -g 1 -l 1 --thread-concurrency 8192 --failover-only
Another question, I'm switching to a Black ICE extreme quad rad, from a swiftech mcp320 that I'm currently using. The swiftech keeps both video card temps +26C over ambient at full load. Room is 31C, cards are 55~57 C, it depends. Would combining both a triple + quad rad make a bigger improvement over a single quad? I'll be using all 1850rpm gentle typhoons.
I get better results from running CGMiner from command prompt than from Guiminer. I'm using something like this:
I'm getting fewer rejects this way. Give-me-ltc is the backup pool, if you don't have an account there or use a different backup remove/replace that entire section. Intensity is at 11 so raise that until you reach 80C.Code:cgminer.exe --scrypt -o stratum+tcp://coinotron.com:3334 -u [username] -p [password] -o http://pool.give-me-ltc.com:8080 -u [username] -p [password] -d 0 -w 256 -v 1 -I 11 -g 1 -l 1 --thread-concurrency 8192 --failover-only
Check your VRM temps, you shouldn't be getting lockups at 80C.
