GeForce GTX 1080 Ti Discussion Thread
Discussion in 'nVidia Flavor' started by DPI, Mar 1, 2017.
  1. Savoy
    Savoy 2[H]4U
    2,467
    Oct 1, 2005
    Got my 2 1080's in today. So far I'm loving them. Played bf1/tf2/SW battlefront mw2 and some crisis 3. Ran benches too. So far so great. Pic taken before install at kitchen table.
  2. Savoy
    Savoy 2[H]4U
    2,467
    Oct 1, 2005
    Fast pic with both installed with Nvidia HB SLI bridge.
  3. Etherton
    Etherton Will Bang for Poof
    6,864
    Aug 7, 2006
    After dropping the CPU OC there hasn't been any more incidents. So far. Here's hoping that it was as simple as that.
    Turned on the on screen monitoring in MSI Afterburner and RivaTuner though. GPU temps reached around mid 50 to 60s. CPU climbed up to the 70s though.
  4. eclypse
    eclypse 2[H]4U
    2,543
    Dec 7, 2003
    Whats rads are you using?
    Dont really remember what my 6700k runs at but prob tops off around 50s overclocked at 4.8ghz.. my 2 1080s at 2190 run at 37 and 32c i believe durring games.
    I use dual tripple 120mm fan rads from ek.. there like 60mm thick.
    All on a single loop using a single pump.
    Etherton likes this.
  5. Endgame
    Endgame Limp Gawd
    183
    Jan 10, 2007
    What is eveyone using for stability testing their 1080ti overclocks? I've been running a mix of Heaven and Timespy, and even fired up star swarm just to see it on the 1080ti, but I'm sure there are better things I could be using. Currently at +150 / +400 and everything is running great (so well that i feel like I must not be pushing the GPU hard enough)
  6. heatlesssun
    heatlesssun Pick your own.....you deserve it.
    48,030
    Nov 5, 2005
    Those are actually pretty good stability tests, I'm doing the same thing. But of course nothing is better than just playing your favorite games. Got mine to 125/400 with 110% power. In SLI, that's about the limit of noise I'm willing to accept with the stock cooling.
    eclypse likes this.
  7. eclypse
    eclypse 2[H]4U
    2,543
    Dec 7, 2003
    Yeah just test with some games that are known to put some good stress on the card.. like witcher 3.. 3dmark firestrike should do it to.
  8. oshia86
    oshia86 Gawd
    586
    Jan 16, 2007
    For those of you who ordered through the Nvidia store, how long did your order take to process? Real anxious to update my two 780's to the ti.
  9. Endgame
    Endgame Limp Gawd
    183
    Jan 10, 2007
    Ordered in the morning, got the shipping notice that night, received the card the following afternoon.
  10. oshia86
    oshia86 Gawd
    586
    Jan 16, 2007
    Awesome. I ordered mine first thing Saturday morning once I caught it in stock. Hoping the card is delivered tomorrow.
  11. Comixbooks
    Comixbooks Ignore Me
    10,585
    Jun 7, 2008
    You think Aftermarket coolers (like the ICX) will be cheaper than the founders edition?
  12. Comixbooks
    10,585
    Jun 7, 2008
  13. Armenius
    Armenius [H]ardForum Junkie
    13,227
    Jan 28, 2014
    I am CPU bound with my Titan X in quite a few games at 2560x1440 on an i7-4770. In those games I'll try to DSR up to 5K. If I don't get at least 50 FPS average I'll bump it down to 4K.
  14. Rvenger
    Rvenger [H]ard|Gawd
    1,360
    Sep 12, 2012
    Not this time. Aftermarket will be starting at ~$710+
  15. Endgame
    Endgame Limp Gawd
    183
    Jan 10, 2007
    Looks like I'm topping out at +155 / +535. It runs at 160 / 550, but I get minor artifacting and bechmark scores decrease from 155/535. +165 crashes to desktop frequently, and flashing textures appear heavily at +575
  16. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    53,161
    Feb 9, 2002
    So far I'm at +150 / + 350. I haven't pushed my cards farther than that.
  17. heatlesssun
    48,030
    Nov 5, 2005
    So what do you think of the noise levels?
  18. Dan_D
    53,161
    Feb 9, 2002
    My CPU cooler is louder than my video cards. I get pretty low ambient temperatures in my office. I'm not having to run the fans all that hard to keep the thermals in check. Again, my CPU cooler is louder than my GPU fans are. I've been pretty happy with this cooler GPU design since it was introduced.
    heatlesssun likes this.
  19. Syphon Filter
    Syphon Filter 2[H]4U
    2,588
    Dec 19, 2003
    Has anyone had Time Spy complete one test but then fail, typically with a 0 score, because it fails to load the next test in the sequence?
    What causes this?
  20. Whach
    Whach [H]ard|Gawd
    1,101
    Dec 22, 2011
    OK. So would everyone here say that a pair OC'd GTX 980Ti's in SLI would approximate a single OC'd 1080 TI? I've been looking around comparing TitanXP benches against 980Ti SLI as there isn't much about a direct comparison. If so, I may just make the swap just to help minimum frames @1600p/4K DSR.
    Anything would be insightful =)
  21. Dan_D
    53,161
    Feb 9, 2002
    From what I've seen that's about right. The other benefit being that you won't be shit out of luck when a game doesn't support SLI very well.
  22. Whach
    Whach [H]ard|Gawd
    1,101
    Dec 22, 2011
    That's what I was thinking =) Thanks for response. Worth making the switch?
  23. Etherton
    6,864
    Aug 7, 2006
    Running a single XSPC RX360 but I just ordered another XSPC RX240 to go in there as well - it was as big as I could go with my case. Replacing reservoir and pump while I'm at it.
    eclypse likes this.
  24. Endgame
    Endgame Limp Gawd
    183
    Jan 10, 2007
    Update on this. I set the fan to 100% while I was away for dinner and I seem to be stable at 160/545 for 4 hours now just letting heaven run. Even with the fan at 100% it wouldn't stay stable at 165/550, and honestly the fan is too loud to be set to 100% all the time. I might even be able to up the gpu to 162 or 163, but I think the quieter fan is the right call at 155 / 535.
  25. refraxion
    refraxion [H]ardForum Junkie
    8,390
    Oct 3, 2007
    Anyone here already do the evga 1070/1080 hybrid install for their 1080Ti? I should be getting mine in sometime this week and am wondering if I should wait for the official one or just jump in and get the 1070/1080 hybrid kit. How do the vrm get cooled with this install?
  26. cybereality
    cybereality 2[H]4U
    2,736
    Mar 22, 2008
    Strangely enough, I ended up selling my 1080 Ti on eBay. The performance was great, but I wanted to support AMD so I put back in the two RX 480s I had originally bought.
    Surprisingly, in games that take full advantage of CrossFire, the RX 480s are about the same as the 1080 Ti. For example in GTA V I can get a solid 60 - 70fps nearly maxed at 4K with both configurations.
    I have a few older games I want to catch up on, so this should hold me tight until Vega. However, I also have a few other systems (one with a Titan XP) so it's not like I'm hurting for performance. The 1080 Ti is still the best buy right now for pure performance.
  27. Dan_D
    53,161
    Feb 9, 2002
    SLI and Crossfire with high end cards has always brought about next generation performance on release. When it works. BTW, if you already bought a GeForce GTX 1080Ti from NVIDIA directly or one of their resellers you've already supported them. NVIDIA got their cash for that card and it impacted their sales figures. You don't really support AMD more than NVIDIA by keeping cards you've already bought.
  28. cybereality
    cybereality 2[H]4U
    2,736
    Mar 22, 2008
    Yeah, totally. I get that. I basically have 4 computer systems in use (completely unnecessary but I just like building computers and playing with them) and I told myself I would maintain 2 Intel/Nvidia systems and 2 AMD/AMD systems. Just to keep things fair.
  29. Dan_D
    53,161
    Feb 9, 2002
    I don't get playing fair with businesses. They don't do it with us. Personally, I don't give a shit who's card I use so long as the damn things work. More often than not I've used NVIDIA cards, but that's just how its worked out with NVIDIA dominating the high end for so long. In a few cases, I tried to go ATI/AMD with no success thanks to fucked up drivers. I had a pair of 4870x2's and two 7970's. I ended up having to replace both sets with NVIDIA cards because of Crossfire issues. I still have that Radeon HD 7970. It's been used on most of my motherboard reviews for the last couple of years.
  30. heatlesssun
    48,030
    Nov 5, 2005
    I think we all want competition to spur innovation and to keep prices in check. But in a free market, buying a product to support competition for the sake of supporting competition? That's just not how it works, nor could most afford that. Back around 12 years ago, most of us rocking Athlons and Radeons because they were at the top, they were good products. I'll support competition when you have something I think is worth my money.
    It's just been so long since AMD has had lust worthy CPUs, Ryzen is good but not great. And now a year into pretty much abandoning the high end GPU market? AMD is just not doing what it needs to do for the higher end gaming market right now.
    Armenius, Savoy and MorgothPl like this.
  31. eclypse
    eclypse 2[H]4U
    2,543
    Dec 7, 2003
    Always fun if ya gots the dough to burn!
  32. Prophecy
    Prophecy [H]Lite
    119
    Jul 27, 2004
    https://forums.evga.com/My-1080-Ti-Hybrid-m2629639.aspx
    Leave the stock baseplate and backplate on, as well as the stock shroud. You're basically using the AIO cooler from the hybrid kit but not the EVGA shroud. This is what I plan to do when my hybrid kit arrives on Wednesday.
    Armenius and refraxion like this.
  33. tungt88
    tungt88 [H]ard|Gawd
    1,922
    Jan 14, 2008
    MSI Afterburner can act really funny in a number of games; the one that I personally have had the most grief with (multiple BSODs, and even straight reboots) was Grim Dawn (which also played havoc with my Sound Blaster X7 LE). Ditto with Afterburner's rivals (Zotac Firestorm, ASUS GPU Tweak, etc).
    For Grim Dawn, it got to the point where some players thought the game itself was at fault, until one determined player showed that it was an Afterburner issue.
    That having been said, Grim Dawn is an awesome game, and everything Diablo 3 should've been.
  34. DPI
    DPI [H]ardForum Junkie
    10,261
    Apr 20, 2013
    ^ never happened.
    Armenius, cybereality and heatlesssun like this.
  35. KickAssCop
    KickAssCop [H]ardness Supreme
    6,453
    Mar 19, 2003
    So guys w/ 2 FE in SLi. How them temps?
  36. Savoy
    Savoy 2[H]4U
    2,467
    Oct 1, 2005
    Well so far I'm just running mine at stock but with precision running and using the default aggressive fan profile as I usually do the temps have been great. Under the heaviest load I've seen so far they have been mid ish60's to high 60's.That's running fire strike and heaven multiple passes and playing a bunch of games at 4k maxed out. Bf1/swbf/crisis 3/tf2/and mwrm. Haven't had time to do much else so far. Today I'll get a chance to play some more games and mess around more.
  37. Nenu
    Nenu Pick your own.....you deserve it.
    17,833
    Apr 28, 2007
    Some interesting results testing overclocks.
    My card is stable at +120MHz/+470MHz at 50% fan.
    I found that core clock speed jumps in 13MHz increments. +120 is the same as +114MHz. The next jump of 13MHz comes at +127MHz so have now set it to +114MHz.
    Increasing fan speed hasnt changed the maximum stable offset value but it does change the clock speed a lot...
    For each +4C change in temp, clock speed will be reduced by 13MHz.
    ie boosting the fan speed and dropping the temp by just 12C can give you an extra 39MHz.
    To further this, increasing the voltage can increase the clock speed a few bins as well, without changing the MHz offset.
    Setting my voltage to +50mV had a small effect on temps but gave me another 39MHz.
    Setting it to 70mV had enough effect on temps to bring that down to +26MHz.
    The same changes applied to my old 980ti but there was much less variation.
    Interesting for my card and perhaps for others.
    Once I found my stable +114MHz at 50% fan speed, I have not been able to increase this going up to 75% fan speed.
    The clock speed increases with lower temp and/or increased voltage but if I change to +127MHz it will crash soon after (when under test).
    It looks like they have got the MHz gradients for temp and voltage change practically bang on.
    revenant and Araxie like this.
  38. Araxie
    Araxie [H]ardness Supreme
    6,008
    Feb 11, 2013
    This has been that way since kepler.. specially since the addition of GPU boost 2 which also was affected by temp and not only by the power target, but 13mhz has been the +/- Offset even when modding the BIOS.
    Armenius and Nenu like this.
  39. Nenu
    17,833
    Apr 28, 2007
    I dont recall the 13MHz jump over only 4C temp change though.
  40. Syphon Filter
    2,588
    Dec 19, 2003
    I don't get how you guys are seeing such low temps with OCs. I'm running Stock FE cards, max power and temp limit and my cards hit 80C.
    What are you ambient temps of those guys who are seeing 60s under OC? /confused.
    Also, any word on the Time Spy error I've seen?
