GeForce GTX 1080 Ti Discussion Thread
Discussion in 'nVidia Flavor' started by DPI, Mar 1, 2017.
  1. Deimos
    Deimos Gawd
    800
    Aug 10, 2004
    BTW, running +215 on the core now. Haven't touched voltage, only increased the power limit.
    Prophecy likes this.
  2. WorldExclusive
    WorldExclusive [H]ardForum Junkie
    10,786
    Apr 26, 2009
    AIO with a stock card is still a better option, like the EVGA 1080 Hybrid. You don't need a custom loop.
    The 1080 STRIX didn't have great QC just like the one before it. Having just experienced ASUS RMA first hand, I'll keep away like the plague.
  3. Fluke
    Fluke Limp Gawd
    493
    Mar 22, 2000
    Anybody doing a displayport daisy chain with the 1080 Ti? Can't get Win10 to see the last 2 Dell U2415s in my 3 monitor setup. Worked fine with the 1080. Cables are certified and short.
  4. RamonGTP
    RamonGTP [H]ardness Supreme
    7,170
    Nov 9, 2005
    That's not what you said though. You didn't say water is a better option. You said anything that isn't water is only for aesthetics which is clearly a false statement.
  5. Comixbooks
    Comixbooks Ignore Me
    10,179
    Jun 7, 2008
  6. WorldExclusive
    10,786
    Apr 26, 2009
    This is what I've been saying:
    It remains consistent. AIO or a custom loop is water. Both use a rad, pump, water block and tubing to cooling the GPU.
    Stock or water. I stand buy it. Custom fans solutions are aesthetics.
    That one has two fans.....oh but this one has three fans, more phases, RGB etc.. None of which will result in higher performance/fps on pascal.
    Savoy likes this.
  7. Syphon Filter
    Syphon Filter 2[H]4U
    2,588
    Dec 19, 2003
    Would it be worth starting a thread where 1080Ti FE owners post their fan curves along with their highest maintainable boost clock (for both stock settings and OC)?
    heatlesssun and WorldExclusive like this.
  8. RamonGTP
    7,170
    Nov 9, 2005
    I can stand by an incorrect statement too, it just makes me wrong. 6db difference between reference and strix. You can preach about standing by your comment in every post for the rest of your life. It was false the first time you said it, it'll remain false each subsequent time you stand by it.
  9. heatlesssun
    heatlesssun Pick your own.....you deserve it.
    46,992
    Nov 5, 2005
    Got my two from nVidia today:
    Two 1080s next to 1080 Tis:
    In their new home:
    Initial benches of RoTR at 4k in SLI seem to be in line with other reviews. Noise levels don't seem any different at stock that the 1080s. But I can easily feel the extra heat when standing behind the exhaust.
    revenant, Armenius, DPI and 8 others like this.
  10. elvn
    elvn 2[H]4U
    2,795
    May 5, 2006
    soon....
    [​IMG]
    Armenius likes this.
  11. Syphon Filter
    2,588
    Dec 19, 2003
    Sweet. Mine should be here later too. Can't wait.
    Have you done any OC yet?
  12. heatlesssun
    46,992
    Nov 5, 2005
    Congrats! And not yet, was plaining on looking at that tonight.
  13. Syphon Filter
    2,588
    Dec 19, 2003
    Mine are here...just installed them. Running Time Spy now. Will post back in a bit.
  14. heatlesssun
    46,992
    Nov 5, 2005
    These are my Time Spy results: http://www.3dmark.com/spy/1389403
    Sith'ari likes this.
  15. Endgame
    Endgame Limp Gawd
    179
    Jan 10, 2007
    Got mine yesterday, but it took until this morning to fully resolve issues with the driver issues.
    My god this is an insane improvement over my 980. when I was doing the purchasing I was pretty sure my ivy bridge at 4896Mhz wouldn't hold it back. Now I'm not so sure, especially since the 1080 ti doesn't seem to like the 102blck
  16. Syphon Filter
    2,588
    Dec 19, 2003
    I just scored 12,853 in Time Spy, does your 6950X and 64GB of memory account for the extra 2,000 points you get over my 4770k and 16GB?
    Just closed f.lux and running again, will post links in a minute.
    I'm coming from 780Ti-SLI. Time Spy was a slide show with those...the jump with 1080Ti-SLI is insane!!!
    EDIT:
    Ok, closing f.lux made little / no difference. My score is here:
    http://www.3dmark.com/3dm/18651382?
    Fire Strike Ultra:
    http://www.3dmark.com/3dm/18651541?
    Regular Old Fire Strike:
    http://www.3dmark.com/3dm/18651621?
    heatlesssun and Sith'ari like this.
  17. Endgame
    Endgame Limp Gawd
    179
    Jan 10, 2007
    Anyone have a recommended overclocking tool / fan profile tool for a Nvidia FE card? I was using Asus GPU tweak (shamefully I was only using it because it came with my Asus 980, never did any research) but am open to using the best available tool.
  18. Syphon Filter
    2,588
    Dec 19, 2003
    I think most people use MSI Afterburner or EVGA Precision OCX. I think either should work with FE cards but I'm not 100% sure about that.
  19. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    52,563
    Feb 9, 2002
    Afterburner does. I'm using it on my NVIDIA reference cards. I don't know about EVGA Precision OCX. I thought that one did a check to see if the cards were actually EVGA cards so I didn't try it.
  20. Syphon Filter
    2,588
    Dec 19, 2003
    Anyone tried Ghost Recon Wildlands? On the Ultra preset at 4k I can barely squeeze 40fps...
  21. Dan_D
    52,563
    Feb 9, 2002
    I have. I get between 45 and 60FPS. It does sometimes dip into the high 30's. It's fucking demanding. SLi doesn't scale well but it does help.
  22. pendragon1
    pendragon1 [H]ardness Supreme
    7,224
    Oct 7, 2000
    i saw a yt vid from some random, they had sli and a 7700(not oc'd) and was getting 50-90fps @4k. so your performance seems aboot right.
  23. Dan_D
    52,563
    Feb 9, 2002
    I wonder why I'm not getting that level of performance?
  24. heatlesssun
    46,992
    Nov 5, 2005
    I'm getting right at 50 FPS average in the canned benchmark with spikes into the 90s. I've not done in game benchmarking but seems to run pretty smooth at 4k ultra present.
  25. Dan_D
    52,563
    Feb 9, 2002
    I get 58.8FPS average in the canned benchmark. I'll have to check when I get home, but there may have been some things not set by the ultra-preset that I changed in the settings.
    heatlesssun likes this.
  26. heatlesssun
    46,992
    Nov 5, 2005
    Hmm, we'll I seem to off in this game as well. Didn't really do a lot of testing just spot checked games with canned benchmarks. Actually played a good bit of Forza Horizon 3. The 1080 Ti definitely is smoothing things out, almost able to keep a constant 60 FPS with brief dips in to the upper 50s. OCing should help out.
    So far very impressed with these cards. And it actually is a pretty significant upgrade even over the 1080, at least at 4k.
  27. Syphon Filter
    2,588
    Dec 19, 2003
    I averaged 56.something on the Ultra-preset but with AA off and Shadows set to Very High.
  28. Nirad9er
    Nirad9er 2[H]4U
    2,229
    Feb 18, 2004
    What monitor are you running? I have 2 coming for my 1440p 144hz setup. I may consider a 4k 144hz monitor when available. I figured 1 is less than my 980ti's at 1500mhz and so I'd need 2 for an upgrade.
  29. heatlesssun
    46,992
    Nov 5, 2005
    Time Spy likes cores so yeah, the difference there is in the CPU.
  30. Savoy
    Savoy 2[H]4U
    2,467
    Oct 1, 2005
    We need a dedicated thread for 3dmark for 1080TI. Firestrike regular, the one in the middle can't remember the name, firestrile ultra and timespy.
  31. Syphon Filter
    2,588
    Dec 19, 2003
  32. Sith'ari
    Sith'ari Gawd
    562
    Oct 13, 2013
  33. caw2007
    caw2007 [H]ard|Gawd
    1,859
    Jan 8, 2008
    I got my Gigabyte FE 1080 Ti yesterday and went ahead and bumped the power and temp limits to max with MSI afterburner. I played GTA V for about an hour and saw clocks up to 1860 on the core but it mostly settled at about 1830. According to the temp monitoring it never broke 70 C.. I have a linear fan speed profile set up so 20C = 20% fan, 40C = 40%, etc on up.
    I get my second card today and my second EVGA Hybrid AIO cooler Saturday. That means next week they both get water cooling! :D
    elvn likes this.
  34. Syphon Filter
    2,588
    Dec 19, 2003
    caw2007 I am seeing exactly the same thing on my FEs. Power and temp whacked up to max and card seems to settle around 1830-60 for me too. I think it's hitting power limit, this image shows 20 minutes or there abouts of Fire Strike Ultra Combined Test on Loop:
    [​IMG]
    Max temps 79 and 74.
  35. Syphon Filter
    2,588
    Dec 19, 2003
    mgulbran Thank you for posting those tips, I will run a test on my machine and report back shortly.
    EDIT: Ok I just tried this @4k using the Ultra preset.
    Turf On - 33.66fps
    Turf Off - 37.89fps
    Not exactly what I hoped for! I'll try some other settings and report back.
    EDIT II: Ok, Borderless kills performance. Run Fullscreen.
    Turf Off - 54.88
    Tur Off / No AA - 67.12
    Tur Off / No AA / Shadows High - 71.44
  36. Blackstone
    Blackstone 2[H]4U
    3,004
    Mar 8, 2007
    What kind of insane feats do you think I could perform with this card at 1080p in GTA V and Skyrim in terms of mods. Right I am running dual GTX 980 but I don't have a lot of VRAM. I expect with this card's massive vram a lot of mods are possible.
  37. elvn
    elvn 2[H]4U
    2,795
    May 5, 2006
    This might be worth investigating.
    1-28-2016
    https://forums.geforce.com/default/...erformance-actually-do-/post/4791706/#4791706
  38. Blackstone
    Blackstone 2[H]4U
    3,004
    Mar 8, 2007
    Would a Haswell-E six core at like 3.6GHz hold this thing back?
  39. caw2007
    caw2007 [H]ard|Gawd
    1,859
    Jan 8, 2008
    Weird thing I'm seeing in 3DMark, my single 1080 Ti was recognized as valid with no problem yesterday. Today my SLI config, even though it clearly shows two Nvidia GeForce GTX 1080 Ti in my system info, every result was invalid because the cards are seen as Generic somehow..lol
    Also of note, in GPU-Z, my Gigabyte branded card shows NVIDIA under subvender, while my EVGA branded card shows as EVGA under subvender and has a different BIOS revision..
  40. heatlesssun
    46,992
    Nov 5, 2005
    So I just started doing some overclocking:
    Ran Heaven 4 and Time Spy, got about a 10% boost in those with these settings. But, wow, gets pretty loud, just about at the edge of being uncomfortably so and a lot of heat. But pretty insane performance. This making think about AIO cooling.
