1080Ti 3DMark Results Thread
Discussion in 'nVidia Flavor' started by Ziontrain, Mar 16, 2017.
  1. Ziontrain
    Ziontrain [H]ardly Working
    2,269
    May 16, 2007
    Hey guys,
    I was going to see if we can get some results from 3DMark..
    I was also going to see if anyone had any watercooled 1080ti results to see if it handles a higher core clock speed.
    Results:
    6700K @ 4.7 Ghz
    1080ti @ +165mhz, +550Mhz on VRAM
    3DMark Link:
    http://www.3dmark.com/fs/11985631
    22.5k on Firestrike Performance
    7.2k on Firestrike Ultra
    Strike_Eagle likes this.
  2. Armenius
    Armenius [H]ardForum Junkie
    12,129
    Jan 28, 2014
    Can you show us the GPU clock graph from 3DMark to see what the Boost clock was during your run? Or are you using the free version?
  3. Ziontrain
    2,269
    May 16, 2007
    Sure. I'll add it as soon as I get home. I ran the fan speed at manual 80% so it didn't dip much at all.
    Edit: Added GPU Results (Core/Mem Clocks)
  4. Syphon Filter
    Syphon Filter 2[H]4U
    2,588
    Dec 19, 2003
  5. KickAssCop
    KickAssCop [H]ardness Supreme
    6,430
    Mar 19, 2003
    I also got something like 7214 or something. Can't remember. FS Ultra.
  6. Syphon Filter
    2,588
    Dec 19, 2003
  7. noko
    noko 2[H]4U
    3,479
    Apr 14, 2010
    Nice score - did comparison between your 2x 1080Ti to 2x 1070 - big difference but then notice the big difference in cpu scores. I recommend you upgrade in the near future your cpu. For 2x 1080Ti I would be thinking more Skylake E or maybe a RyZen rig except I think pushing two pcie3 8x in SLI on either the 1151 or X370 is starting to become limiting for today top end card and gpu's tomorrow.
  8. Syphon Filter
    2,588
    Dec 19, 2003
    Cheers!
    Yeah, my machine is getting a little long in the tooth now. Waiting to see how Ryzen plays out and what the Intel response is.
    For gaming @4k I'm not really losing out that much so happy to hold tight for now.
  9. noko
    noko 2[H]4U
    3,479
    Apr 14, 2010
    3dmark means shit for actual gaming performance on the total score. I find it useful for optimizing, overclocking, stress testing etc. since it gives consistent data not only DX 12 stuff but cpu as well. 4K, 2 1080Ti and a I7 4770K should work well and probably 0 difference in experience with any higher performing processor on the planet. For a single 1080Ti I would recommend a RyZen, for SLI ->Skylake E is probably the better bet, also depending upon price.
  10. Syphon Filter
    2,588
    Dec 19, 2003
    Indeed...hence I'm happy to sit tight for now. Hell, there are people still rocking Sandy Bridge machines, I'm in no rush ;)
  11. BroHamBone
    BroHamBone [H]ard|Gawd
    2,022
    Apr 6, 2013
    Armenius likes this.
  12. KickAssCop
    6,430
    Mar 19, 2003
    That's tight. Which AIO though?
  13. BroHamBone
    2,022
    Apr 6, 2013
  14. KickAssCop
    6,430
    Mar 19, 2003
  15. Savoy
    Savoy 2[H]4U
    2,467
    Oct 1, 2005
    Thought you picked up a second card. Maybe I misunderstood your other post in your SLI thread.
  16. sprout2287
    sprout2287 Gawd
    852
    Jul 30, 2007
    Here's mine:
    6700k at 4700
    Using precision X
    gpu clock offset +200
    mem clock offset +525
    Firestrike Ultra 7540 http://www.3dmark.com/fs/12118657
    Tilespy: 9708 http://www.3dmark.com/3dm/18844127
    Full loop with 240 rad before GPU 360 rad before CPU. EK FC block on the GPU.
    Ran logs in timespy. Temps didn't break 36. Gpu stayed at 2075through the first test, hovered around 2000 for the second.
  17. KickAssCop
    6,430
    Mar 19, 2003
    Waiting to pick up 2 ASUS STRIX in SLi.
  18. KickAssCop
    6,430
    Mar 19, 2003
  19. Savoy
    Savoy 2[H]4U
    2,467
    Oct 1, 2005
    Ahh I see.
  20. Supercharged_Z06
    Supercharged_Z06 [H]ard|Gawd
    1,883
    Nov 13, 2006
    Like the OP, I'm also curious to see what a waterblocked/OC'ed 1080Ti can do in 3DMark. While the 1080Ti is promoted as being ever so slightly faster than a Titan X at stock speeds, It seems to lose that distinction when both are properly waterblocked and OC'ed. My Titan XP score for Fire Strike Ultra is 7835.
  21. sprout2287
    sprout2287 Gawd
    852
    Jul 30, 2007
    You've got a few MHz on my core speed @2114 vs my 2076
    But I've got a few on you memory-wise with 1507 to your 1386mhz
    Your GPU score was 8078 to my 7647
    My cpu is pushing a slightly better 14859 to your 13103, but it still yields a lower overall score
    Still on the first day of pushing mine, might get a little closer if I add a little bit more on the gpu. I'm waiting for my aquaero (enroute from Deutschland) to get my fans in check, currently running of the pwm signal from the cpu fan header.
    Full loop is xspc RX240 (56mm thick 2x120) rad > EK titanXP block, > xspc RX360 (56mm thick 3x120) > xspc raytstorm > ddc res
    First loop since the LGA1366 days. Feels good to be back. AIO was so half-assed.
  22. Syphon Filter
    2,588
    Dec 19, 2003
    I thought these cards would clock as high as possible until they hit either the temp limit or power limit (90*C and 120%). But that's not what I am seeing.
    Can someone explain how these cards clock up / down?
  23. Vellinious
    Vellinious n00bie
    53
    Oct 23, 2015
    The cooler the core runs, the higher it'll be able to boost. With boost 3.0, the card will either drop frequency or drop voltage to help keep the core temps down....this happens about every 10c or so. I've seen it at work with core temps as low as 15c (coolant temps at -6c)....
    The best way to overclock pascal is to learn where those "layers" are at for your GPU, and avoid them at all costs.
  24. jkw
    jkw Gawd
    579
    Oct 10, 2004
    Timespy 10,320 - http://www.3dmark.com/spy/1025287
    oh wait, this isn't a Titan XP thread.
    Signed,
    bitter Titan XP owner who paid twice your price a few months ago for something that barely beats yours
  25. jpouza
    jpouza n00bie
    16
    Nov 17, 2014
    jkw likes this.
  26. Strike_Eagle
    Strike_Eagle n00bie
    7
    Mar 31, 2017
  27. DuronBurgerMan
    DuronBurgerMan Gawd
    643
    Mar 13, 2017
    Nice results... since I'm running on a very similar rig to yours, how'd you get 'em? I'm maxing out around 9,300.
  28. NukeDukem
    NukeDukem [H]ard|Gawd
    2,035
    Feb 15, 2011
  29. Strike_Eagle
    Strike_Eagle n00bie
    7
    Mar 31, 2017
    Wow. i didnt realize that CPU made such a large impact on your score. your running an i7, and me an i5. however you get almost 17 more fps in the cpu test. which is good for another 1600+ marks. Interesting!
  30. CFOUR
    CFOUR n00bie
    8
    Jun 14, 2015
  31. DuronBurgerMan
    DuronBurgerMan Gawd
    643
    Mar 13, 2017
    Okay, best Time Spy run so far is 9,965. Which is frustrating because I know I can tweak just a hair more and crack 10,000. Maybe just a hair more CPU and GPU clocks, and I'll get it. Best run at stock speeds was around 9,300.
    http://www.3dmark.com/spy/1480262
