Dion
- Oct 2, 2004
285.76 drivers are not even on the Nvidia site. this physx version is new as the last driver on the site had 9.11.06.21.
Not sure why they aren't there.. But they have been out awhile now.
Just played BF3 for about 20 minutes with new drivers. Seems okay. No new problems but still no 99% usage in SLI.
Its weird; in the game if I face an empty place on the map, like looking out over non combat area I get full 99% usage but as soon as I turn back towards the action usage on 2nd GPU dips to 80%-75%. Only played on Firestorm so maybe more testing needed. Perhaps some one in here has a solution or at least an explanation for this phenomena.
I had never even heard of them before you mentioned them. from what I can find that driver was unofficial so that's why it was not on the Nvidia site.Not sure why they aren't there.. But they have been out awhile now.
yeah its your CPU holding back your GPU's
i did quite a bit of benchmarking on my system (specs below) with my CPU clocked to various speeds and core counts and my 2500k even at 4.5Ghz becomes the bottleneck in BF3 multiplayer much of the time, esp on large maps. my 2x 560 Ti's utilization will vary anywhere from 75% all the way to 99% on both cards depending on where i am at in a map. (i run v-sync off and cannot run maxed out settings due to a lack of VRAM so my cards always have performance to spare in this game)
A member on the NVIDIA forums linked me to this: http://www.sevenforums.com/tutorials/33641-screen-refresh-rate-custom-nvidia-brand.htmlThese drivers are completely unusable for me (which hasn't happened in a while). Whenever I install them, my screens turn incredibly blurry. Text is almost unreadable. Roll back to 285.79 and it's fine. I did clean installs of both drivers. Very odd. I saw someone else on Guru3D mention they had this problem. Anyone else experience it, or have suggestions on how to fix?
I don't know how it fixes the problem. But you realize I was quoting myself, right?Rizen, how does that fix his problem? that looks to be nothing more than a fix for the 59hz refresh rate that some drivers stick us with. I had to do that for that couple of drivers myself.
I already did. how do you think I got the drivers for this thread? 285.76 drivers are not on the Nvidia site and have to be downloaded elsewhere. I even saw a couple of comments saying they were not official drivers.Look in the "Beta and Legacy Drivers" section.
those are 285.79 NOT 285.76.I don't know why or how it doesn't appear for some people then... Try typing the direct URL. [H] doesn't let me hyperlink to for some reason.
http://cpg.us/GeForce285.79.png
need a little help here:
when i open Nvidia control panel > Manage 3D Settings > Program Settings, Skyrim is not automatically added to the list. so i manually added steamapps > common > skyrim > TESV.exe to the list, but the Ambient Occlusion setting is greyed out and reads "Not supported for this application". anyone know what i'm doing wrong here?
Reinstall the driver and use the "clean install" option.
AO gives shadows better detail. In Skyrim you can see it around characters feet, objects, etc. Quality setting does take quite a performance hit, so use Performance or turn it off if you notice slowdowns.i did a clean install the first time around. i found that if you untick the box for "Show only programs found on this computer" you can select Skyrim from the list and change the settings. i'm just unsure if they're actually being applied. tried AO on Quality and Off, don't notice a difference between the two. i notice a huge difference in BF3 between the 3 AO options.
How are these drivers doing for BF3? Any noticeable performance increase in frames?
Just a heads up, with this driver it's possible to enable FXAA with NVInspector for DX9/10/11 games too, earlier this was possible for OpenGL games only.
More about this: LINK
P.S. You should disable any type of in-game AA before experimenting with this feature, not all games are compatible, some are crashing/not launching.
My avg FPS dropped from 80 down to 60 from 285.79 to these drivers, however, it seemed to have smoothed it out a little bit, but the drop to 50~ fps is still not acceptable for me.
How long before we get the ability to force FXAA from the control panel, directly?
It's something I've definitely longed to see! FXAA Injector (the .dll replacement) works well enough for now, I suppose, and it's great to see that NVInspector handles it, but...gimme control panel options!
Well that was fun, installed these and when I went to enable SLI again, I was treated to a black screen. Had to boot into safe mode to uninstall them. Back on 280.26 for now :/
Interesting that the HD audio driver got a such a major numerical increase.
I wonder if they finally implemented HD bitstreaming?
Either way, the last beta driver they released was a total mess for me. Anything has to be better than that one was. Got my first blue screen in years with that one.
Funny considering this set is meant to help to "fix" the problem. lol
