Xenon's CPU has three 3.0 GHz PowerPC cores...
Xenon's GPU is a generation beyond the ATI X800. Its clock speed is 500 MHz and it supports Shader 3.0.
Xenon's hard drive is optional.
Xenon will have a USB 2.0 camera. It's capable of 1.2 megapixel still shots and VGA video. Photos can be used in-game and for gamer profiles. The camera can also be used for video chat.
DirectSound3D has been dropped in favor of X3DAudio.
Microsoft is requiring developers to make all Xenon titles be mandatory Live "aware".
All Xenon games can be played using custom soundtracks.
The baseline is 720p at 1280x720 for gameplay and video clips, 16:9 aspect ratio, 5.1 Surround Sound, and anti-aliasing. These features are the current minimum requirement.
Ballz2TheWallz said:they dont go 1080i because interlaced looks horrible
all these specs were rumored over 6months ago
Ballz2TheWallz said:fear the power of the R5xx series which rapes 850 series and a 3core 3ghz ppc prcessor capable of pulling 6processes per clock
and the XNA has so much power why didnt anyone belive specs before gamespy?
Blinkme323 said:yeah, I am really dissapointed by the memory too. I am probably going to end up buying a PS3 and Revolution instead.
bountyhunter said:if this thing is only going to be 500mhz I don't think there will be any raping...unless it has like 32 pipes....
Sizer said:Regarding the hardware...
I don't care how fast or wanked out their RAM is. 256 megs is 256 megs, period. Unless they use godawful DXT compression on every texture excepting normal maps (which would use 3dc), they won't be able to stuff enough media assets into memory. There are only so many tricks you can pull out of your sleeve.
24-32 is suspected,new corebountyhunter said:if this thing is only going to be 500mhz I don't think there will be any raping...unless it has like 32 pipes....
go into task manager when running doom3 at max and find its process and look at its ram usage...thank youTiny said:It doesn't have to run XP in the background. It is dumb to equate it to ratios in a PC system.
I pretty much did the same thing. I bought the PS2 first and then got a Gamecube when the price droped because of the great exclusive titles.Blinkme323 said:I like my Gamecube a lot but I didn't buy it on launch. I will buy the PS3 when it first comes out and wait until the Revoulion's price drops.
The Xbox 2 GPU is prolly 500Mhz with 24 pipes. The R520 for PC will likely be 700Mhz with 24 pipes. 700Mhz with 32 pipes would be insanely fast, but it is kinda out of reach if you ask me.Ballz2TheWallz said:24-32 is suspected,new core
i HIGHLY HIGHLY DOUBT that there 2nd best core will be 200mhz less then there best thats just stupidtrudude said:The Xbox 2 GPU is prolly 500Mhz with 24 pipes. The R520 for PC will likely be 700Mhz with 24 pipes. 700Mhz with 32 pipes would be insanely fast, but it is kinda out of reach if you ask me.
Ballz2TheWallz said:go into task manager when running doom3 at max and find its process and look at its ram usage...thank you
you didnt read mine,you can SEE WHAT RAM THE GAME ALONE IS USING along with the overall systemTiny said:comprehend my post. thank you.
It is running NOTHING but the game, therefore the ram specs NEED NOT BE as high as you see in PC systems.
Ballz2TheWallz said:you didnt read mine,you can SEE WHAT RAM THE GAME ALONE IS USING along with the overall system
jerk
jmgak47 said:It is all B/S three cpu's?![]()
Jonsey said:Is the 256 mb shared or does the GPU have it's own dedicated memory?
its shared....cache and ram are differnt god, if you wanna bitch with me take it to xboxscene forums where people who actually have a clue on this postShifra said:256mb is for the system alone, the GPU uses its own cache.
R520 is 24pipes, its already been confirmed.
jerk
Ballz2TheWallz said:its shared....cache and ram are differnt god, if you wanna bitch with me take it to xboxscene forums where people who actually have a clue on this post
