For a complete stock setup and not using a video card temps shouldnt be a problem at all if the case has decent cooling properties.
What kind of aftermarket cooling [HSF] would you guys recommend to put into this mobo? I am planning using this mobo with a E6750 in a MicroFly case.
-Carlo
So, what gives? Are there really two different DS2R models? Or something more funky is happening?
I have heard of a problem with the Gigabyte G33 boards, very similar to what you're describing. It seems the earlier BIOSes had a lock mechanism option the new ones don't have. Meaning that, if for some reason that lock mechanism was tripped (user-based or otherwise), the BIOS would flash only once, resulting in the kind of behaviour you're experiencing.Since I have no floppy drive, is there any other way/program to safely flash the bios? Can Qflash use something other than a floppy disk?
new to the thread, just wondering if there are any utilities I can use to monitor cpu or motherboard temps?
Has anyone rma'd their board? I sent mine back to giga-byte over a month ago when it stopped working and haven't heard a word since. Is it common to take this long?
With the added bonus you can actually control the fan speeds with Speedfan... heheheI use both CoreTemp and SpeedFan for my temp monitoring.
Correctso, if i'm trying to hit 3.0 with the q6600, i need to set the FSB to 333 with the default 9 multiplier, correct?
Usually 1:1 is best when OC'ing, because it doesn't stress the memory as much. With that level of OC, you could perfectly get by with DDR2-667 sticks on 1:1. It's waaaay to late for me to make the 4:5 333:? math (I'm practically sleeping here...), so please check how would your DDR2-400 sticks work with that divider.what should the mem divider optimally be set at on this board (my sticks will be 800MHz DDR2-800/PC2-6400 5-5-5-18 timings default)? i've heard that the F4A bios should allow a 1:1, but is stepping down to the old bios really the best thing to do? also, should i manually set the voltages for the cpu or keep it set at auto, and will this overclock most likely need a voltage bump?
Some Wolfdale action with BIOS F8a (works with 2.00 divider and even 1.6) !
[email protected], 2x2GB A-DATA Vitesta Extreme 800+@907MHz, 5-5-5-18 2T, (video onboard)![]()
