ChronoDetector
- Apr 1, 2008
I just recently bought a LG 55UB850T which has a native resolution of 3840x2160 and currently using it as a monitor. However, when I set it to its native resolution, the text looks fuzzy and blurry. I have already set the sharpness but it had very little effect. However, if I use a different resolution, such as 2560x1600 or anything under, the text will look fine. Is there a workaround for this?
