GoldenTiger
- Dec 2, 2004
Here is the latest... launch during CES 2012 (Jan 10-12).
EDIT NEW INFO
http://www.brightsideofnews.com/new...-mix-gcn-with-vliw4--vliw5-architectures.aspx
I've edited in the 7970PRO speeds for clarity.
Some quotes from XS...
B3D's neilz is saying there won't be much of a perf/transistor improvement.
Quick summary of change from AffenJack:
So there you have it... the rumors have taken shape and seem pretty firm at this point.
EDIT NEW INFO
We'll see how accurate will this turn out to be...
"Ladies and Gentlemen with graphics card upgrade plans, circle the date January 09, 2012, for this is going to be the day AMD will launch its next generation high-performance graphics cards in the Radeon HD 7900 series, according to reliable market sources DonanimHaber spoke with. On the 9th, AMD is expected to unveil at least two new SKUs in the HD 7900 series, most likely, HD 7970 and HD 7950. These will be based on the new 28 nm "Tahiti" silicon that will use completely redesigned number-crunching machinery, and a very wide memory bus."
http://www.techpowerup.com/156641/January-9-Launch-Date-for-AMD-Radeon-HD-7900.html
Starting next week, AMD is going to organize Tech Days in several destinations around the globe, such as London or Paris - during which the company is going to present 28nm Radeon HD 7000 series.
There is a lot of rumors flying around the web, some of which are spun by AMD themselves to raise confusion, as the Radeon HD 7000 series is going to mix the existing VLIW4 and VLIW5 architectures with the "Graphics Core Next" (GCN), introduced during June's Fusion Development Summit held in Bellevue, WA.
Sentential @ XS summary said:Radeon HD7970XT:
2048 processing cores 1ghz
128 Texture Memory Units
3GB GDDR5 (384bit) @ 5.5ghz
MSRP $450
Radeon HD7970PRO:
1920 processing cores @ 900mhz
120 Texture Memory Units
1.5GB GDDR5 (384/256bit) @ 5ghz
MSRP $350
For Comparison:
HD6970
1536 Stream Processors @ 880mhz
96 Texture Units
1GB GDDR5 (256bit) @ 5ghz
7970XT against 6970 would be:
33% More Shaders
33% More Texture Units
13,6% Higher Clock Speed
65% Higher Memory Bandwidth
51% more Gflops
Add a bit higher Efficiency of GCN to it and we are at a normal 70% jump like from 4870 to 5870.
