Yea why would you replace the front fans with... smaller ones?
What ever. I just fund it dumb spending $500 on a air cooling setup. You do you.
Ain't the new fans like $40 each plus $150 for the new cooler?
This. No need to reinvent the wheel.I really think this is pointless a d a waste of money. The only thing I would of done is add a rear fan.
Being included doesn't inherently = bad, especially on a premium product.What's the problem? 99% of stock fans are garbage that immediately gets relegated to the parts bin anyhow. Going with new quality fans vs stock is the norm.
Fractal fans are decent, and optimized for the cases they are sold with. But I mean I won't stop anyone from fooling around with their own setups if they want to.
The default Fractal Torrent setup has been reviewed and measured and consistently topped many charts though.
Maybe, maybe not. He may have increased the torrents cooling effectiveness by 25% maybe more! Who knows. He's definitely not alone in how he configured his rig. The first thing I would've done with that case, or any case for that matter, is replace the fans with some ippc 2000s. Fans are cheap as chips in comparison to what we pay for everything else in our systems afterall. You may as well do it up exactly the way you want it...or what's the POINT?It is not a down grade just pointless most of us believe.
Just a small aside, I don't think that's the reason. I think they believe they can improve it to some measurable degree that offsets the cost in the first place.for no other reason than he chose to be different.
same speeds, but lower noise and lower airflow.If the new fans can run at a higher speed whilst maintaining the same or lower noise floor,
Maybe, maybe not. He may have increased the torrents cooling effectiveness by 25% maybe more! Who knows. He's definitely not alone in how he configured his rig. The first thing I would've done with that case, or any case for that matter, is replace the fans with some ippc 2000s. Fans are cheap as chips in comparison to what we pay for everything else in our systems afterall. You may as well do it up exactly the way you want it...or what's the POINT?![]()
One things for sure. He's a hell of alot less likely to share any more of his valuable info after all this negativity. It seems like some folks are being wayyy to critical of dudes decision to upgrade his fans for no other reason than he chose to be different.
I get loving your case in it's stock configuration and believing yours is the best way. And I understand trusting review sites to guide you in how you choose to run your rig. But there's nothing wrong with thinking outside of the box. Particularly when you own said box. All this unnecessary negativity that's being shown towards polony because he's switching fans? C'mon. He spent a few bucks and made his rig HIS. That's what being [H] is all about. It's not like he bought a bunch of RGB shit...
Polony, keep on doin you.
no that's not the reason...I don't care at all about trying to 'offset the price' of the fans or trying to save money...if I cared about the cost I wouldn't have bothered getting the Noctua's and would have used the default layout...I know I'm paying more for most likely a very small gain...but I like Noctua...have used them in all my cases since forever...my main reason for upgrading is as I explained earlier:
1) having a uniform 140mm fan output across all fans inside the case which I think makes for better airflow...2) possible improved GPU temps...Gamers Nexus did a video where they showed the default Torrent fan layout was excellent overall but it wasn't doing as good a job on the GPU...not terrible temps but not as good as the CPU...3) the 2 180mm theoretically should be quieter than 3 140mm fans but this is Noctua we're talking about so I'm thinking it's a draw at best
none of the 5 ive built in ticked.I've also seen multiple reports of noise/rattle with the Fractal 180mm fans...I'm not saying it happens to everyone but there are reports out there...
https://www.reddit.com/r/FractalDesign/comments/sqvomm/torrent_case_ticking_fans/
https://www.reddit.com/r/FractalDesign/comments/18k0yw5/noisy_clickrattle_dynamic_x2_gp18_fans/
6db is a ~4x increase, so it is pretty significant. Of course, if the noise floor is around 40db then the point is moot.theyre getting to be like ek...
1: no, youre dropping airflow.
2: see above
3: the noctuas are quieter but your going from 2 180s at 31db to 3 140s at 25db(peaks). so idk how thats gonna work out.
My PoV is from the real world of living with the case. I already simply can't hear anything and temps aren't even close to a concern.which I think makes for better airflow.
Again, 4090 owner here in this cases stock configuration.. thing is dead silent on its default fan curve.possible improved GPU temps
What is the rest of your new build? What could use a bump in spec for better performance?
I’d get a bigger and better power supply for headroom. Maybe even a large storage drive. Simples. Other than that, looks like a nice spec list.7800X3D
ASUS TUF Gaming X670E-PLUS WiFi
G.SKILL Trident Z5 Neo Series AMD EXPO 32GB (2 x 16GB) DDR5 6000 CL 30 RAM
ASUS TUF Gaming RTX 4080 SUPER 16GB
Samsung 990 PRO Gen 4 NVMe 2TB
Samsung 860 EVO 1TB 2.5 Inch SATA III SSD (secondary drive)
Super Flower Leadex VII XG 850 Watt 80 Plus Gold PSU
Fractal Design Torrent case
Noctua NH-D15 CPU cooler
Noctua NT-H2 thermal paste
It is enoughI’d get a bigger and better power supply for headroom. Maybe even a large storage drive. Simples. Other than that, looks like a nice spec list.
yes yes,otherwise, that power supply is super affordable in your micro centerNever said it wasn't. I said for more headroom for more components. read the sentence the fella![]()
except they are not. look at the specs, i did, so i knew i wouldnt be spouting garbage.....He won't lose anything,that fans NHA14 are better than any others
I don't understand anything, if you know which ones are better, then tell,except for these new noctua, which come out later for the case and which are $40 each.except they are not. look at the specs, i did, so i knew i wouldnt be spouting garbage.....
https://www.microcenter.com/product...t-80-plus-gold-atx-fully-modular-power-supply
https://www.microcenter.com/product...etics-platinum-atx-fully-modular-power-supply
It is better to buy the same one only from 1000w
I had a 550w super flower, I think I sold it with a pc build or separately, I don't remember anymore.Super Flower is not as well known as Corsair, Seasonic etc but they are one of the absolute best PSU's you can get...the hard core enthusiasts know about Super Flower...I was too lazy to make a trip to Microcenter and ended up buying it from the Newegg Super Flower store for $164
scroll back a bit, i listed the specs. he loses airflow with both noctuas but they are quieter.I don't understand anything, if you know which ones are better, then tell,except for these new noctua, which come out later for the case and which are $40 each.
yes, it is your choice to downgrade, didnt say otherwise. it is a decent amount of airflow lost, just a fact. again, you do you.it's irrelevant as far as actual cooling losing that tiny bit of CFM...the noise (dBA) makes a bigger more noticeable difference...plus the 3 140mm fans in the front means air reaches lower in the case...in the end the differences are minute and all about individual preference...there is no right or wrong way...using all Noctua's versus using the stock fans is just a choice...a Ford vs a Chevrolet...both will get you to the same destination
