- Aug 29, 2004
OSUguy98 said:what about this one?
http://www.newegg.com/Product/Product.asp?Item=N82E16817104953
Keep on Folding!! For the [H]orde!!
That one will do just fine.
The only thing to watch for is it is an ATX12v2.0 PSU (and like some ATX12v1.3)so if someone loads the 5v higher than the 12v though they may have an issue with the 12v running out of spec. This should only pertain to AXP setups that are regulated on the 5v. We can either be sure to recommend a motheboard setup that regulates the CPU off of the 12v or a different PSU for the AXP's.
