Domingo
- Jul 30, 2004
Finally, I feel justified in overpaying for a 3090!
Yeah it looks fine. It's a far better tropical jungle than FC3 but that's to be expected.is good graphic?
Thanks must get cash and buyYeah it looks fine. It's a far better tropical jungle than FC3 but that's to be expected.
they made some nice changes to the Assassin's Creed formula starting with Origins but I guess they were content to leave the Far Cry experience relatively the same...new setting, same basic gameplay...I got FC6 for free so I'll be playing either way but I was hoping this would be the best FC game
As well as changing the formula = people whining about changing what worked and what they liked -- "don't change the Coke formula, didn't they learn from Coke?!"For most big studios changing the formula = longer, more bloated grinding quests.
I happen to like the Far Cry formula, openworld action without needing to invest into a 400hr RPG.
They had the right idea with 5, the interesting setting was enough to make up for the lack of game improvements.
Unfortunately Far Cry 6 looks like a mixture of 3 and 4, they hoped Gus Fring will be enough to carry it. At least the previous games had unique villians, sure they got an A-List actor, but it's still a familiar character from all his previous roles.
I really liked 5 and New Dawn (less so), I hoped they would continue to surprise us.
Not enough video ram.... try turning off the hd textures I am sure the issue will clear up... rx5700 has only 8gb memory right?I keep getting vram limit issues with HD textures on in 1080p Med with RX 5700
Yes it has 8Gb .. I notice in the results for benchmark is says 7Gb of vram for system info for video cardNot enough video ram.... try turning off the hd textures I am sure the issue will clear up... rx5700 has only 8gb memory right?
Well that depends on more of the same what? FC5 or New Dawn? The former is OK, the latter is hell no for me. BTW Uplay is down right now, so there is plenty of time to decide if I want to play this or not.Initial reviews are as expected. More of the same, but if you like the formula there's no reason you won't like this one, too.
Guru3D did a rundown of how performance works: https://www.guru3d.com/articles-pages/far-cry-6-pc-graphics-performance-benchmark-review,1.html
The 10GB on the 3080 was never enough. Even before this game there were a number of titles that would use more than 10GB quite easily at 4K. This is the main reason why I didn't bother getting one since I had a 2080ti at the time. It was a downgrade in VRAM.Techpowerup says this:
What's really interesting is VRAM usage. I measured well over 10 GB with the 4K, HD Texture pack, and ray tracing combo, which does stutter sometimes on the 10 GB GeForce RTX 3080, but runs perfectly fine with cards offering 12 GB VRAM or higher. I guess I was wrong when I said that the RTX 3080's 10 GB will suffice for the foreseeable future. That said, there's plenty of graphics options, and I wouldn't be surprised if a future patch addresses memory requirements.
They also showed that FSR Ultra quality gives a little better than native image quality, in this game. And a lot of GPUs are CPU limited at 1080p and even 1440p. Will be interesting to see if Alder Lake can make a dent in that.
You don't have a sig showingRig in Sig, Game Runs very nice... This is with HD Texture Pack active and everything in the game cranked... no FSR
I think that would be because the benchmark may show what your system can use at once. Ie if your card has 8gb, how can it show your system using 10gb vram, you know? So 7 to 7.x gb is the most your system can utilize. Rest will result is dropped frames, latency, etcYes it has 8Gb .. I notice in the results for benchmark is says 7Gb of vram for system info for video card
Just buy it from Ubisoft Connect and cut out the middle man.Is HD resolution pack available on Epic launcher version of the game?
https://www.epicgames.com/store/en-US/p/far-cry-6
Fixed it for you in the previous post.You don't have a sig showing
Edit: nvm, I guess sigs don't show on mobile
HD Textures are a free download it does not matter where you get it...Im pretty sure the HD textures are free DLC? i got the game free from buying an amd laptop last year, and i was able to download the HD textures.
So one could subscribe to Ubisoft+ for one month, play this game, then maybe cancel the subscription?
Yeah now I have the sudden urge to play Far Cry 2 again.Far cry 2 was soooo good.
Far Cry 2 is the one game in the series that I never played.Far cry 2 was soooo good.
Good to see that they paid a little more attention to the small details that can really immerse you, even though it still doesn't have the same level of detail in those aspects. That is something developers and artists started straying away from as the focus became the chase for shinier graphics. But those little details are what made games special.
Those RPGs flying off into space in FC6 really got me laughing, though.
