- Jul 24, 2008
* Made sure the gate before the boat sequence stays open forever after the initial button pressThe patch in-progress is 10x the size of the previous hotfix/patch.
Currently 1100 fixes.
https://www.reddit.com/r/fallout4london/comments/1fdriqt/recent_updates_on_future_patches/lmiesh0/
Coming... eventually.
* Fixed issue where the button to open the gate becomes uninteractable if you leave and come back
Shit like this is a major issue in the mod. If you happen upon a locked door that is related to a mission you haven't received yet, they will allow you access to it before hand but not when you actually gain the quest.
Even quest lines where you do them right and have a final door to traverse, you're locked out of it and have to use the unlock command through the console to open it. Quite a few have you leave and come back only to find the door is locked and can only be open with a terminal which you have no access to.
If it wasn't for the console, this mod would be unplayable.
* Atkins robots can no longer eaten with cannibal perk. Damn it!
