- Aug 5, 2013
Your defense should be >= your food + water combined. I always keep mine about +5 higher and at one point after fast traveling to Graygarden it was completely destroyed. All of the turrets, water pumps, and food sources. I had to spend resources repairing them... The game didn't warn me of an attack or anything. So I think it's RNG.I'm not even sure how the mechanics work for it. Like if your defense is higher than everything else, does it NEVER get attacked, or just much less likely?
If one gets attacked when you're not there, does it radio you for help and then you head there and help defend it?
If your defense is too low, you will get periodic raider attacks that you can help defend (supposedly).
If you're not sure what's wrong with your base, check the "Data > Workshops" Tab in your pipboy. It will show <!> symbols on every base where there is a problem. Beds, food, water, defense, etc, it will warn you. It's a very simplistic game mechanic. Most of the 'fun' comes from customizing your bases, which has NO EFFECT on how they function... It's just for aesthetics. If you don't care how your base looks, you can construct a fully functional settlement in about 10 minutes.
edit: Unrelated, hi-res game map:
http://i.imgur.com/ulR8sGB.jpg
