Has there been any progress on 20-30-20 yet? It sucks that eyefinity isn't usable with the best config.
ahhhh... yes.. me likes. Hey, they even have some wallpapers also.![]()
Yeah , kind of funky resolutions. but I made them work for mine
Right.. with the general lack of wallpapers in the 5ksomething x 1ksomething category I am hording any I find.
Here's my setup: 3x Dell P2310H, powered by 5970
Diverge: Can you post the overall width of your setup there from top outside corner to corner?
I'm trying to decide between the P2210H or P2310H.
One of my biggest concerns w/cheaper displays is actually viewing angles, 'specially if you're using them in PPP mode (w/TN panels), that's my biggest problem w/Eyefinity right now. I don't wanna step down from 24" on my main display but the only affordable IPS out there is the 22" Dell. Maybe I should make a poll to see how many people are running 3x1 w/TN panels and how many are doing so happily in PPP mode.
HP ZR22w may be to your liking next month.
I have a 27" Samsung 275t and want to use Eyefinity on my HD5870. Should I sell it and buy 3 23-24" LCD's or keep the 275t and buy two 23-24" 1920X1200 LCD's? I do like my 275t monitor.
That Samsung 275T monitor is awesome, just get 2 more, or at least get 2 Dell 2709W, they can be found on Craigslist or e-Bay for like $550.
Why would you get 23"-24" to go along with a 27" monitor in EYEFINITY ? It will look really bad with the image being off
You sell any of HP's or LG's IPS-based models? That would be optimal if you plan to run 'em in portrait mode (much better viewing angles), to a 23-24" IPS panel will typically cost 1.5-2x as much as a TN panel.
That's the problem. I think they are all TN. Do any of Co. I listed make IPS LCD monitors? If so do you know the model? Thanks for the help.
Meh, viewing angle specs on TN panels are kinda bunk anyway if you ask me...
What do you guys think. I have a HD5870 and will be buying two more 27" 1920 X 1200 LCD monitors to complete my Eyefinity setup. Do you guys think that one overclocked HD5870 will be enough for that setup? On youtube I have seen a lot of setups that run with one HD5870 and it seams to be fine.
Wow, that is the EXACT same desk I have had for almost 5 years. I love it.
Now as far as my setup, I have a Dell 2709WFP that I purchased last year. It was on sale, so I got it for around $700. It has a max resolution of 1920x1200, so I tried a 24" Scepter x24wg-naga as a 2nd monitor just to get a taste of Eyefinity and it was amazing, though I need a 3rd for sure.
So now I'm trying to figure out if adding another sub $200 24" 1920x1200 for a 3rd display is worth it to get cheap 3 monitor gaming, with a nice center monitor. I think the difference in size and bezel aren't as noticeable while gaming. I mean yes 3 similar monitors would be great, but I can't spend $1200 to get 2 more, and I see they need to be PPP or LLL, so this seems like a decent option without spending much. Also, I found myself always concentrating on the center monitor, so I think the 2 side monitors can be less quality like this, just to provide the immersion.
However, I definitely noticed input lag on the 2709. I read about it before buying it, and most people said it was not an issue unless you put up a cloned screen next to it. I was very surprised that the 24" Sceptre was so much faster than the 2709. Moving my camera around, I could measurably see that the 2709 was slower. However, it looked much better than the Sceptre, which was darker, and colors were not as vibrant. When playing on only the 2709, I never notice the lag, even if I look for it, though.
So, slight size difference, bezel, and input lag, would you guys say I should try to sell this 2709, and just get 3x2310H (wife will kill me most likely), or just get another cheap 24" 1920x1200 and live with it until I can replace both 24" in the future?
I also looked at ASUS VK266H 25.5" 1920x1200 monitor at $300. Maybe I could get this instead for now, and replace the 24" sceptre with a similar model in the future. I'm not sure how PPP mode would look, but I still think it's worth a try.
Here is a shot of my temporary setup in the living room:
http://img691.imageshack.us/img691/8910/img6819d.jpg
Once your eyes cross the bezel, the size difference (and bezel for that matter) don't really matter.
Thanks for any comments.
What desk is that exactly? Where can you purchase?
so lemme get this straight
I can run Eyefiniti as
2 DVIs and a DP cable
OR
2 DVIs and a DP with a converter to VGA
right?
i know VGA looks like shit but does the converter make the VGA look good with the other 2 moniters that are running DVI?
