Really thinking about going Eyefinity with 3 BenQ XL2420T, what do I need to do to make this happen?
I am building a new gaming rig, parts should all be orderd within 2 weeks. What I really need advice with is what GPU setup to go with. I also am still looking for a Mobo so if any one has any good ideas that would be great!
PSU: CORSAIR Professional Series HX850
SSD: Corsair Force Series GT CSSD-F120GBGT-BK 2.5" 120GB SATA III
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155
CPU Cooler: CORSAIR H80
I am currently using a GTX690 to power 3x27 Samsung 120hz monitors. If money is not an option I can't recommend that card enough. Card has 3 dual link DVI's to hook up your monitors+has enough power to play any current game at 60fps+ @ 5760x1080.
Either that or I am sure SLI 670's/660Ti's would be ok.
These eyefinity setups are seriously epic. But in all honesty, how many of you actually use all three LCDs at the same time besides gaming?
I do all the time and I use 3 30" monitors which would be overkill for a lot of people. I multitask a lot and have a lot of desktop space allows me to see a lot of windows at once. This increases my efficiency a lot. Can I use 1 monitor? Yes. Do I prefer it? Hell no.
Pardon my horrible Sketchup abilities.
You really should look to angle the side monitors - putting them all on the same plane with anything more than a tiny screen will probably not be ideal.
Figure out where you will sit and try to make each screen perpendicular to the viewer
That would be a bad idea if he plans to game, wouldn't it? I don't know a single that that does not assume you're using flat display / flat configuration of displays.You really should look to angle the side monitors - putting them all on the same plane with anything more than a tiny screen will probably not be ideal.
Game assumes you are using flat display display / flat configuration of displays and distorts the image accordingly.I think most people who game tilt their monitors in so they are all (more or less) perpendicular to their own face. The wrap around experience is ideal in almost all cases. I don't know what there is to be gained by having all monitors on one flat plane.
@ rtangwai
this is righteous! love 3x20 above the plp setup. However, whats the heat like in the room, i have heat issues with just the plp setup i have.
your so luck! I live in az and needless to say summers blow here -____-. 110 degree weather sucks.
Apparently some games, like iRacing use 3 different cameras for angled multi-monitor configurations ("3 render mode" or something similar in case of iRacing). Link.I don't disagree. The game assumes the displays are flat, but most gamers would rather see that distorted image straight on rather than at an angle. The image looks bigger instead of small because of the perspective. Also, take it from me and others here who use eyefinity regularly, you don't notice it at all. The wrap around effect is much nicer and easier to look at.
If viewed at correct angle, image should look absolutely normal, no bigger or smaller than usual (talking about flat configuration with rectilinear projection).most gamers would rather see that distorted image straight on rather than at an angle. The image looks bigger instead of small because of the perspective.
