your so luck! I live in az and needless to say summers blow here -____-. 110 degree weather sucks.
I lived in Arizona. In fact I was there the day the record high temperature was set in Phoenix which was around 1990 I believe and the tempeerature hit 122F. It wasn't that bad. Count yourself lucky. Nice temperature drops at night, virtually zero humidity. Yeah it's scorching in the summer time but the winters are quite nice. In Texas our weather is unpredictible. I've seen 14" of snow in Febuary and snow on the ground for the better part of two weeks. We've seen snow in April and hailstorms in July. Then a week later were in triple digit temperatures with humidity that basically tops out the meter. It's worse in Houston. Triple digit temps more frequently and humidity which defies most scales. 15 minutes doing something physical outside results in sweating all the way through your clothes. Then when you go inside the sweat never evaporates. It just dries in a sticky mess of salt patterns and you get swamp ass virtually every day if your outside enough.
