LegendKiller said:No matter what I do, even if it's 1mhz over, I can't get the vid card to take an OC through the Nvidia control panel with nTune installed.
Could somebody who has gotten it to work post the exact versions they are using?
Has anybody gotten the CPU to OC yet?
AthlonAlien said:Man, I am having the EXACT same problem. Running Vista with the newest nTune (5.05 I think)... it will fail even at 1 MHz above stock AND when you do an Optimal Test it will drop the speed from factory 450MHz to 427MHz!!! The card is not hot at all... I think there is some software glitch here?
Has anyone tried both Vista and XP 32-bit and made a comparison? I was wondering if Vista ate a suffiecient amount of the system resourses on this machine. I reformatted the laptop as soon as I got it and put XP x64 on it. The drivers for x64 in this thread and others I've found seem a little buggy. Is it more optimized on Vista?
DragonMasterAlex said:I've run it with Vista (Resource pig) and am currently running XP 64 and XP 32bit in dual boot. So far the best experience is hands down XP 32 bit. Under Vista my gaming performance was just *horrible*.
I'm posting this for my friend: Is there a button to turn on or off the wireless connection? His laptop cannot see his wireless connection despite him placing the laptop right next to it. Is this a just connection problem with the Atheros card people have been talking about or did he not turn on the wireless card?
I'd help him but I'm at school now. My friend just got the laptop today.
Thinking of getting a 3rd stick of ram for 3gb, bad idea?
cpu 72
gpu 71
harddrive:33
these okay temps after exiting stalker?
game runs good on 1024x768 with 2 gigs ram on medium
2 gigs of ram = teh sweet![]()
cpu 72
gpu 71
harddrive:33
wonder what temp monitor program u have ?
Thanks,
phatbx133
the everest program from oldversion.com i think thats the site![]()
which version did u use it that works for vista ?
Everest Home Edition 1.10 (2.6 MB)
Everest Home Edition 1.51 (3.0 MB)
Everest Home Edition 2.01 (2.8 MB)
Everest Home Edition 2.20.405 (4.0 MB)
thanks a lot.
phatbx133
bahh only 2 slots hehe. It can hold up to 4gb though am I right?
Why dont companies like this sell laptops that are fully upgradeable?...there'd be a huge market for that. Essentially turn laptops into PC's. Replacing motherboards, processors, everything!
LOL. i am running xp. sorry![]()
When you installed XP, did you have to create an XP Install CD with integrated chipset or SATA drivers, or did the standard XP w/SP2 bootable cd work and then you just installed chipset and sata drivers later?
just a xp sp2 bootable cd. you only need the sata driver for raid i believe.. i did keep 2 46 gig partitions, and deleted that pesky 5 gb one in the windows setup. that way if i ever need to format, i can save my stuff on the second partition, and its already there, so i didn't have to work hard to make it
I am considering getting this for using with autocad, softimage, 3ds max and some other graphics apps. Do you think this will fit the bill? I am a little worried that the wxga+ screen 1440*900 will be too cramped (would prefer wsxga or wuxga resolution).
I am also wondering if I should get the 3 year warranty with accidental damage for $200 extra? Is anyone else buying the extended warranty?
comments appreciated
Thanks!
Anybody have any luck getting a refund for Vista?
I called Everex and they said I had to get it from OfficeMax. I called OfficeMax and they said I had to get it from Everex. I called Windows customer service and they're closed on weekends. Runaround city!
Also, I asked Everex customer service about getting a higher capacity battery. They said the 6-cell that ships in the XT5000T is the highest capacity battery they make. Boo!
