I don't use wireless so I always have wireless turned off so thats not an issue.
The temps are for idle cpu - 54C and gpu - 64C.
Would it help putting some artic silver on it?
oh man. i should have waited to get one thenHazaa I should be getting my XT5000T by Thursay or Friday
Found a great deal for an almost new in box unit for $500 with an upgrade to 2 gigs of memory and a second 100gb hdd already installed and working.
Can't wait to tinker with the laptop and see what it can do.
I use Vista x64 on my XT, and it still dies often when using the WiFi. So crappy. I wish this could be fixed w/BIOS updates.these irq issues suck. worse than ever now with my new cpu, seems to have aggravated the issue. i may try vista to see if that makes it any better
i'm using the new intel abgn wireless card
I have not posted on the Everex forums for this issue.have you posted about this on the everex forums for this model?
Personally I don't like wireless for any computer I use I am a die hard network cable freak.
I do plug-in when using the XT at my desk, but in the living room, WiFi is better than stretching the 50 cable I keep around for (re)builds.
Monitoring != responding. This is a known issue.I'd go post the issue on their forums I am sure the company monitors the forums.
I just got my XT5000T in the mail today.
This is one sweet laptop.
Just did a clean install of the OEM Vista (I'm going to give it a chance before I put XP Pro on there) and installing all the important updates now..![]()
I decided to give the drivers linked in this post: http://hardforum.com/showpost.php?p=1030845205&postcount=124 a shot.
For cooling someone over on the Everex forum wrapped the heat pipe with copper wire and claims great success. I haven't tried it but sounds logical. Maybe check it out.Has anyone taken apart the case/housing for this laptop yet?
I'm going to do some mods I have planned for it after looking over the unit.
I see some issues with cooling I want to improve on.
The plastic casing doesn't look too problematic to remove.
Once I get the project started I'll post some pictures here.
There you go.
I don't really care for Vista anyway, but I especially like XP for the Everex. Vista's video demands can easily drive the heat up, even when the candy is off. It is hard to compare numbers because so many people use XP on the Everex. Just a thought.
Hey Syngen, check your optical out port and make sure it's working. I too got my system RMA'd and I went to connect my notebook to my home theatre system and the optical out port isn't working now. it worked perfectly prior to sending it in... used it often too after getting my mini toslink cable.
Santech wrapped some copper wires around the heat pipe after slathering it with paste.Has anyone taken apart the case/housing for this laptop yet?
i feel ya. i traded away my xt5000t. i'll get another laptop one day but for now my smart phone is pretty good and holding me overI have two of these notebooks. Mine is showing severe symptoms of the black-screen problem. My wife's is completely dead, despite many tries to get it working.
How many other people are having this problem?
This reminds me of the Deathstar saga, I am starting to think it's going to result in the same thing.
Were you running XP or Vista? I notice it runs warmer with Vista. Maybe the video chip problems increase with the extra heat. These are toasty little numbers any way you cut it.I have two of these notebooks. Mine is showing severe symptoms of the black-screen problem. My wife's is completely dead, despite many tries to get it working.
These people are truly hopeless. I called them the first week and talked to them about the heat. Mentioned RMClock and they accused me of overclocking. They look for any reason to void warranty.
I don't know if they are as dumb as they sound or just hamstrung by company policy.
