Guess I suck at linking. Search for 5045745.
upgrades i will get for laptop:
2 of these. yeah refurb, but i've had luck with seagate refurbs in the past. 100 gig 7200 rpm drives (2) $126 total
2 gigs of thisddr2 667 $100 total
definitely need a mouse $35 bucks
Backpack of course$55 from the 'egg
$316 total. hopefully i can sell the current gig of ram in my laptop plus the harddrive, to help me get those totals down to $216. i can't wait!
I just bought one of those for $39 from BestBuy of all places!Backpack of course$55 from the 'egg
does the extra hdd drive need a caddy or will it fit just fine wihtout one?
yea 100 bux for ram is a good deal .
For those who already have the notebook, can you remove the chip and upgrade it?
Point of interest: Under the general System Properties it shows a TL-50, but in Device Manager under Processor it shows TL-56 (!!!) Who's telling the truth? I've already discovered the Atheros 5005 chipset the computer is supposed to have is reported to be an Atheros 5006 - did they upgrade the processor too?
Has anyone dug into their computer and jotted down the numbers on the processor?![]()
How about running CPU-Z?
Man, I'm trying to hold off upgrading this bad boy because I bought it and don't even use it.![]()
Wondering if anyone else has just a little bit of backlight bleed at the bottom of the screen?
Andy
Yeah, it does not sound very good. Without any tweaks, straight out of the box I was getting 2215 in Vista on the 3dMark06 ! Try different drivers first, before tweaking any hardware. Also make sure that the power option is set to full power and not some saving setting.mobilecomand said:hmm well after a complete reinstall of my lapper with everex drivers for xp with all of the windows patches i managed to get a staggering 1974 in 3dmark 06..
there is a major issue.. just need to figure out if its software or hardware now...
Hi Guys,
anyway I think Everex need work on new bios things they need address issues list below
1. In Device Manager at Processor show report wrong TL-56
2. fix arthero drop bconnection or poor connection( users)
3. fix keyboard thingy
4. fix disabled or enabled wireless status led panel light (unable disabled turn off wirless led always on)
5.fix in bios to allow increase 256 to 512mb video card( anyone who have 2gb system, do u see any increase 512mb?);
6. fix speaker thingy
phatbx133
Hi Guys,
In Device Manager
things i disabled.
built in conexant type 1 modem (softmodem not good) let resources free
IEEE 1394 host controller since i dont have any device
artheros and nvidia controller disabled since dont have high speed net.
storage microsoft iscsi Initiator (sdcard reader?)
plan next upgrading
1. mini portable hub 4 or 6 port usb with low watts
2. buy a reasonable price for portable backpack
3. portable webcam with 1.3 higher
4. wirless a/b/g usb thumb for portable where i can go wifi or hotspot
5. ram and hardrive put on hold till any new vista games come out like halo 2, gear of war pc, etc...
7. cant think of anyhing else...
phatbx133
Greetings, fellow Everex owner
1. Mine says TL-50 in device manager (are you using XP or Vista, I use Vista... it might be a problem with XP?).
2. Yes, this problem sucks! I spoke with Everex and they confirmed it was an issue. They told me whenever the signal drops... to disable then re-enable the Atheros card in device manager...sad (I will try the driver 'phatbx133' linked to).
3. Are you refering to the Enter key situations? As others have posted, you can use a program to 'swap' the Enter keys back around and to disable the slash mark...
4. My wireless status LED goes off when I turn the wireless switch on the front off (are you talking about disabling it in device manager)?
5. Not sure what you are asking... by default it will use about 256MB of system RAM (total combined of 512MB)... when I upgraded to 2GB, it can now use about 512MB system RAM (combined of about 768MB).
6. Speaker thingy?! what is this issue... I have seen it say no playback devices found when coming out of standby... I had to reboot the laptop to fix it (may be a driver issue)?
-Thanks and an excellent list!
I agree with almost everything, but I think you missed something.
8. Add RAID0/1 support in BIOS
Also, mine does not show a TL-56 in Device Manager nor in BIOS. Maybe you got lucky and *actually* got a Tl-56? Have you run CPU-Z to verify?
I spoke with a nice tech support guy from Everex today. This wasn't a lackie like I talked to the first time. RAID 0/1 support IS in the BIOS. You have to have 2 drives installed for the option to appear.
This is great info, hopefully someone will try it asap and get back with the outcome. Itching to pull the plug on 2 7200 drives if this is the case.
On other issues I finally ran into the Atheros card not working yesterday. One thing I did notice when it happened was it also disappeared from device manager.
