Errors on Prime 95!!!
jhego
Uh oh, i ran the test twice and both came out with errors. What should i do?!!?
Means the system isn't 100% stable.
Back off your overclock maybe?
BTW ...... your image is much too big.
QFT
When Prime95 errors, it'd because the system gave it a value it didn't expect. i.e. your computer f'd up.
Are you running overclocked? How are the temperatures in your system?
im not overclocking and my temp seems fine. Here is the 3rd test that i took. Still getting errors...
If your voltages are stable, I'm inclined to say your RAM could be bad. Download and run Memtest86 for a couple of full passes.
Also, which test have you selected in Prime?
You shouldn't need to bump the vcore if the cpu is at stock speeds and the voltage coming from the PSU is good.
could be memory no?
try relaxing your memory to the max and see if still happens...
also, it looks like those programs contradict with regard to vcore.. might want to set vcore manually vs. auto to see if that helps
it would help if you would post your full rig
mal
malicious said:
damn .. lots of peeps helping this guy
another vote for memory check
lol
So far we've got:
1. Run a few full passes of Memtest86
2. Manually set the vcore in your bios.
I used the test In-place large FFTs. I'll try and do memtest. I did set the RAM manually to 2.5-3-3-6 since it was advertised that way. If set in auto, it goes 3-6-6-8.
So your cpu is overclocked? Generally that error refers to lack of voltage to the cpu. Need to back the overclock off or raise volts. To test that, put the cpu back to all stock settings and see if it still happends. You know its the cpu if it stops doing it at stock speeds.
I havent started overclocking yet. They are running on stock speeds as you can see on the picture. Where do i find the vcore on the bios? Or do i look for it somewhere else?
I'm using my lappy right now since the desktop is running memtest. So far so good. Pass 70% and no errors yet *crosses fingers*.
Check in CPU-Z how fast you're running your memory at. Are those timings 2.5-3-3-6 spec'd for the speed you're running? What's your mem divider?
yea the timings are 2.5-3-3-6 and im running memtest as i type and no errors yet. When set in auto, it reads 3-3-3-8. No idea what the ram dividers but i'll let you know later. Corsair site is advertising it like this thats why i bought it. If the memtest passes, then all i can think of is upping the vcore like what these guys suggested. Im reading the BIOS manual right now trying to figure out where the vcore adjustment is located.
regarding the vcore, it is set on auto. Do i still need to up the vcore? Since it on auto, doesnt the BIOS supply enough voltage?
When you set the timings, did you set it directly like 2.5-3-3-6?
Because on my DFI, if I do that strait down the BIOS line, the timings will come out as 2.5-3-6-3
I have to set it as 2.5-3-6-3 to get 2.5-3-3-6
(Hope that made sense).
yea, i know what u mean. I did it right. When you run memtest, it shows exactly like this CAS : 2.5-3-3-6. On the CPU-Z, it reads it like that from top to bottom. On the bios, i changed the TCL and TRAS.
It is very possible that your PSU isn't supplying the proper amount of voltage to the CPU. Try and manually set the voltage in the BIOS so that it matches your stock vcore. Make sure that both the asus probe and cpuz read the same voltages. if it isn't working after that, bump up the vcore one notch, and run the test again.
if it works after that, then the psu just isn't supplying the proc enough power. You then have the choice of leaving it at that vcore, or purchasing a new psu.
I just bought the OCZ Powerstream 520W 2 weeks ago. Do i really need to purchase another PSU? I'll try to manually bump the Vcore to 1.50.
when i say that the psu isn't supplying the correct voltage, it could just be that the psu was defective to begin with. so just give it a shot to manually set the voltage, test it, and if it isn't ok try and set the voltage one setting higher than stock.
if everything is OK after you've set the voltage higher, then you'll be presented with either the option of RMA'ing the psu or leaving it at that setting.
I didn't know PSU can be unstable too. I mean, if its unstable, it would just not turn on at all. I wonder if there is a PSU stress test :D Well, i bumped the vcore to 1.50 and im testing it now as i type. If its still unstable then i'm gonna have to RMA it on Monday.
lol psu stress test :p
its quite weird that its giving errors on stock settings i think its the cpu itself...
The PSU doesnt become unstable, however if its unable to supply enough stable power (read stable voltages) for the system, the system will become unstable. Best way to stress test a PSU is to run Prime with in-place large FFTs, while looping 3dMark. That'll cover max heat output and max power consumption.
does super_pi pass?
perhaps try 2t instead of 1t to see if its a crap mem controller on the cpu
id definitly grap a multimeter and take a reading on your power rails just to be safe, but it doesnt sound like power to me.
try vcore at 1.45-1.5 to see if it becomes stable, if it does take out your cpu and RMA it, because clearly it cant run at stock voltage.
kleox64 said:
memory, also load default BIOS options.
yeah lets make it run really slow....
seeing as how this guy is at stock speeds all the vcore bumping in the world is just helping to prove he has a bad chip. his voltages look ok (i dont like the 3.2 on the 3.3 but it should still be fine) and it apparently memtests ok. but there have been some complaints about the OCZ PSU's as of late. borrow a PSU from a friend to confirm thats not it then RMA the chip guy.
Well guess what. After bumping the vcore to 1.50 and ran it overnight, there has not been a single error :eek: So does it come down to bad processor or bad PSU? If it's CPU, then tough luck for me since i bought this a year ago OEM and i dont know about their RMA policy. I can however RMA the PSU since i bought this at Monarch on Jan 13 and i have to do it soon. I mean what's the risk am i getting if i keep the PSU but on manual vcore? Do i have to constantly change it everytime i install something and run Prime95?
Well, if thats the default vcore (i think it is...but i'm too damn tired to google) then you shouldn't have an issue. If that is beyond the default vcore, I would definetly RMA the psu.
Hmm, when i checked the BIOS after loading the default setups it was on Auto. How can you check the default vcore? The CPU-Z and Asus Probe still shows the vcore at the same level so i guess this is the default vcore???? It's weird, i mean why didnt the BIOS supply the right voltage if it was on Auto. I thought Auto means self adjustable? :confused:
Yeah, turns out that 1.5 is your default vcore. Don't know what to tell you about auto, except that you mobo might just have been having problems with automatically setting it. Not a big deal if everything is cool when its manually set.
If its just the mobo then i dont really care about the auto thing. Well i guess that solved the problem. I would like to say thanks to all of you who took the time to check this thread and gave a little advice. We all sure did learn something especially me. Most thanks to the ones who kept telling me to bump the flippin' vcore already, lol :D But don't let it stop you from posting if you would like to add something else.
well since this thread is "case closed" and it turned out to be the motherboard i think it's fitting that i mention that
MY NEW PUPPY"S NAME IS MOBO!!!!!!!!!! LOL
Lol, Mobo.... That's a good one. Make sure you train him so he won't gigabite your ass :D
reduce your cpu multiplier to try a lower cpu speed to rule the cpu out
also swap out the ram or try
1/2 t timings
cas 3-4-4-8 for stability
flash to newer/more stable bios
start swaping parts to see what is screwing up this could very likeley be your motherboard v-regs are craping out or getting too hot
Most times if you set auto, BIOS should detect it right. I personally never had a mobo that didn't. What proc are you using btw? check on intel or amd website if that's really the right default vcore.
To really see if its your psu, run speedfan or other monitoring prog and see how flat your voltage lines are when the system is under load.
