mr-busta said:Most times if you set auto, BIOS should detect it right. I personally never had a mobo that didn't. What proc are you using btw? check on intel or amd website if that's really the right default vcore.
To really see if its your psu, run speedfan or other monitoring prog and see how flat your voltage lines are when the system is under load.
AMD Athlon 64 FX-53
Socket 939
Core: ClawHammer
Clock Frequency: 2400MHz (2.4GHz)
System Bus: 1600
Operating Mode: 32/64
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 1MB
CMOS Technology: 130nm SOI
Im on default right now so i guess there's nothing to worry?
PSU voltage is almost flat. The jump goes from 1.488V to 1.504V most of the time.
