DanMan1464 said:well i did the fix #3 for warcraft III
it works for a bit, then it goes back to the 2fps / instant scroll thing
sometimes it returns to normal, but most of the time it stays that way. Any way to permenantly leave it normal?
Out of curiosity, are you doing any OC of your graphics card? I don't know exactly why, but when OC the GPU with a dual-core system I get odd behavior at some clocks that I didn't a single core. But when I lowered the OC on the GPU by a little bit the freezeing, low FPS would go away.
Perhaps, due to Dual-core optimizations in both the ATI and nVIDIA drivers now, the GPU is pushed a little further even at stock than with a single core CPU. This would cause the OC's on a Dual-core to exceed what may be stable under a single-core application. The net result even at the slightly reduced OC was still faster than with the single core so it's a good trade-off.
Let us know if this was the case and the result.
