I originally intended to combine a HTPC and server into one for my basement but I realized I'd be doing too much tweaking on the server and accessing it remotely to allow for consistent and convenient access to it as a HTPC and decided to split it into two machines.
I'm now trying to decide what hardware to use for each task. This is what I have right now:
Office / Gaming PC:
Server / HTPC:
Old PC:
The X2 7750 system is old and probably near EOL. It used to run quite well running Windows Home Server with Plex and a bunch of other server applications while the X2 245e ran as a HTPC but I always wondering if I'd get better performance from Plex Media Server while transcoding and streaming if it was running on faster hardware. I've got a Roku XS that I don't use because I don't like waiting for files to buffer (transcode or whatever) before they'll play so I don't use it.
I've been considering upgrading the office / gaming PC to Ivy Bridge (buy a second hand mITX board and CPU) which would mean I have the Clarkdale parts to use as a server or HTPC. This would probably be the most expensive and the most time consuming.
I could also buy a used Sandy Bridge system to run as a server, use the X2 245e as a HTPC and sell / give away the 7750 system. This would be less work and less money.
The simplest would be to leave the Office PC as is, leave the X2 245e as a server and get a decent case for the X2 7750 to run as a HTPC.
I just don't know how much power I should have for my server. Thoughts?
Office / Gaming PC:
- Core i3 540
- Zotac H55 mITX
- 8GB DDR3
- Sandisk Extreme 240GB SSD
- Sapphire Radeon 6670 LP
- Antec ISK300 mITX case
Server / HTPC:
- Athlon X2 245e
- Gigabyte GA-MA785GM-US2H mATX
- 6GB DDR2
- OCZ Vertex 2 100GB SSD
- Radeon 5570 LP
- Silverstone LC35 HTPC ATX case
Old PC:
- Athlon X2 7750
- MSI K9N2GM mATX
- 4GB DDR2
