D
Deleted whining member 223597
Guest
The multiboxing has to do with a lawsuit regarding WoW IIRC. They banned someone in WoW for doing it, he sued them and won.
Quadrupling your drop rate seems nice.The multiboxing has to do with a lawsuit regarding WoW IIRC. They banned someone in WoW for doing it, he sued them and won.
Just came back to D3 after a 5-6 month leave of absence. I'm very disappointed to find that they never fixed the jerkiness and "rubberbanding" when you move around. This is something they broke with 2.0 that they apparently are never going to fix. Settings seem to make no difference at all. Any word on this from Blizzard?
It happens to me once every few days.rubber banding us almost always a network issue. I would look into your own network first.
It depends on the location. Sometimes it's for more than a sec, sometimes it's a few seconds. Now granted I don't clear out my background tasks (Waterfox with 100+ tabs open all the time), but I'm running on:
[email protected]
16GB RAM
780 SLI
on an RoG Swift and I see my usual framerate sitting at like 144Hz... and then it just randomly dips to 40 and under. It's not necessarily correlated to action, it just seems random. The game's coding is just terrible.
Turn off sli, it causes negative scaling in d3. The game is much smoother with sli off
I play a M6 DH, currently paragon 330ish with a full build including TnTs.
Don't really like how the 2.1.2 patch latest hotfixes has killed DH damage... they're supposed to do the most because they're also the weakest class health wise, but blizzard doesn't seem to agree. I also liked the relaxing gameplay because it doesn't hurt my hand.
2.1.2 DH is still berserk, but the play style is slightly different.
Basically, you need another piece of gear that will allow you to use a spender for free in order to activate the sentries. Kridershot is the most obvious, but also the most difficult to get. The other option is Spines of Seething Hatred that allows for Chakram spam. Spam Chakram as your primary until you're full up, then drop Cluster Arrow until you're bottomed out or everything is dead, then rinse and repeat. With Kridershot it's the same thing but with Elemental Arrow.
The changes make multishot worthless, so you get an extra free slot. Now there is the easy option to run both smoke screen and vault. Or alternatively Marked for Death for increased damage.
CDR is as important than ever as it affects sentry recharge speed.
Overall I'd say the changes buff DH, but the problem is it's more gear dependent than ever. It's going to be even harder to be a top tier DH. But, I think the same is true with the other classes. Waiting to get a Furnace drop as an example is maddening, or SMK for that matter.
I would rather have the patch with possible bugs than the stale crap we have right now. Not saying it's going to make it way better, but it will add a tiny bit of fresh air.
I have a pair of Kridershots I used on my secondary DH's. They weren't that rare when I found them as I found quite a few, but they were weak and no sockets. The Calamity is pretty rare as I've only found 2 in 2 years.
The 2 I have are a little stronger and I was able to use the Gift to socket them.
The Krider on the left is like mine, top tier. I just of course rolled it to 10% increased damage, and not AS, it does nearly 3k damage. It is still quite a rare bow though. I have only ever gotten one. The same can be said about Calamity. I've only ever gotten one of those as well.
I'm not certain of which class to play next season. I am tempted to do something entirely different for me and play Barb. I went to DiabloProgress just to see the leader ranking, and I figured it would be DH, but apparently it's Barb! And it's Barb by a decent margin too, by 3 gRift levels. I have no idea why no one is talking about that (and instead either playing or complaining about DH).
I may play DH again, but I don't savor trying to get a Krider. I'm tempted to play WD, but once again to play that top tier, SMK or Furnace is required. I think this is why I'm most tempted to play Barb. Easier to be top tier as none of the gear required is ultra rare (although getting a good roll on everything is of course hard).
Fake edit: NM, Barb also requires Furnace... ugh, rest of the gear is easy though.
I don't think it requires it. I was doing some grifts to level up gems and then a barb joined with a Maximus. He was a pretty high level player, and I looked at his gear and he actually had all of his gems at level 50. Probably tells me he was one of the best barbs on the server, but he was using a Maximus.
Well, unless he did have a Furnace, too, and he just swapped them around depending on what he was doing.
I have both a str and int Furnace now, but I just kinda stopped playing... I can't quite get myself back into it. I just went ahead and started Dragon Age 2.
Even after the hotfixes where they removed sentry bonus damage? Finding that a bit hard to believe, but I guess I will (have to) see.
I only ever found one Kridershot and it was before I hit level 70. Hate everything.
Also with the SS nerfs, is it even worth using anymore?
SS = smokescreen I think.
100% XP buff is active on Korea, December 25th to midnight December 29th.
Should be starting in ~12 hours for North America, if we're going to get it.
No announcements on the site for us (yet).
